Can i programme a F/Fitted single button remote 2 my E30 Cab
Vincenzo
Post Mon Aug 01, 2011 2:28 pm
Guys
I am in the process of buying a1993 E30 Cab which has a factory fitted alarm with remote locking. (It does not have the old BMW funny key alarm in the driver's door).
This car comes with one remote only, a "single" button type as below:
Does anybody have any idea on how to programme this to the car's alarm system please?
Vincenzo
Post Mon Aug 01, 2011 2:43 pm
Vincenzo
Post Mon Aug 01, 2011 6:24 pm
Thanks for the post but there is nothing there i can find that helps!
Vincenzo
Post Mon Aug 01, 2011 7:33 pm
I'm afraid OE E30 alarms aren't quite sophisticated enough to be programmed by any of the methods in that link.
They are hard wire programmed, by soldering across gaps in printed circuit board tracks and/or cutting gaps in tracks.
If you can find an identical model of fob to one that works, you can open them both up, and change the wiring around the chip of the new one to match the working one.
If you don't have the matching fob to the car, you can open up the alarm module, copy out the coding in the tracks around the coding receiver chip, use the internet to find the matching coding for the transmitter chip in the fob, then adjust that to suit. All a very long winded job, and these days, much easier to swap the whole thing for a modern unit from the likes of Rightclick (Sp?), and get two brand new fobs.
