Post
Mon Aug 01, 2011 7:33 pm
I'm afraid OE E30 alarms aren't quite sophisticated enough to be programmed by any of the methods in that link.
They are hard wire programmed, by soldering across gaps in printed circuit board tracks and/or cutting gaps in tracks.
If you can find an identical model of fob to one that works, you can open them both up, and change the wiring around the chip of the new one to match the working one.
If you don't have the matching fob to the car, you can open up the alarm module, copy out the coding in the tracks around the coding receiver chip, use the internet to find the matching coding for the transmitter chip in the fob, then adjust that to suit. All a very long winded job, and these days, much easier to swap the whole thing for a modern unit from the likes of Rightclick (Sp?), and get two brand new fobs.
