Windscreen wipers not working properly
Gimmethat
Post Sat May 07, 2011 9:52 am
My wipers do not work properly on intermitent. You have to hold the stock down to keep them working as soon as you let go they stop in the middle of the windscreen. Is this a motor or switch problem
eko
Old timer
Post Sat May 07, 2011 10:05 am
Common problem.
Have a read through this to get an idea of what you need to do.
http://www.esatclear.ie/~bpurcell/318is ... html#wmisf
Gimmethat
Post Wed May 18, 2011 1:25 pm
Many thanks have tried that but must be something else either relay or the motor itself do you think
Post Wed May 18, 2011 1:30 pm
Do the wipers work and park properly on the normal and fast settings?
jbee
Post Mon Aug 01, 2011 12:29 pm
hi all, better late than never, i got this problem i changed the stalk, motor and relay but nothing has changed and the wipers stop anywhere on the screen and the mot is due lol :eek: any help would be nice
cheers phill
**BANNED**
Post Mon Aug 01, 2011 1:11 pm
With the linkage dis-connected from the motor,does the linkage move freely?
Youth is wasted on the young.
jbee
Post Mon Aug 01, 2011 3:07 pm
yup, everything is free and greased up
polsta
Post Mon Aug 01, 2011 5:51 pm
my problem is..the constant/fast constant work ok
but the 1 tap down for 1 wipe, and the up 1 click for every 5 second wipe, dont work ? any help on that ?
**BANNED**
Post Mon Aug 01, 2011 5:54 pm
polsta wrote:my problem is..the constant/fast constant work ok
That's switch/relay related,I think,is there any rubbish under the relay in the fuse box?
Then try a replacement switch.
polsta
Post Mon Aug 01, 2011 6:19 pm
i dont think so, what relay is it in the fuse box ? i have spares from the breaker, is a switch/relay the same thing ?
**BANNED**
Post Mon Aug 01, 2011 6:26 pm
Relay is the long black one in the fuse box,they have a habit of trapping fuse's under them,causing all sorts of issues.By switch,I mean the stalk on the steery column....sorry.
polsta
Post Mon Aug 01, 2011 6:33 pm
ah ok, il check that relay out, will the one from a 1990 is be exact same as an 87 sport ?
i dont think its the switch/stalk mind
jbee
Post Mon Aug 01, 2011 6:34 pm
i changed the motor, relay and the switch and theres no change
polsta
Post Mon Aug 01, 2011 6:39 pm
jbee wrote:i changed the motor, relay and the switch and theres no change
must be gutted :( :twisted:
jbee
Post Mon Aug 01, 2011 6:43 pm
yes just a bit lol dont know where else to look now
MurphyE30
Post Mon Aug 01, 2011 7:39 pm
mine has this simptom too. when i use the 1 wipe the wipers stick in middle of the screen on way back to there position
rossmc88
Post Mon Aug 01, 2011 7:42 pm
I have a known good wiper motor forsale, £22 delivered
PM me if you want it
Ross
jbee
Post Tue Aug 02, 2011 4:59 pm
sorted the wiper problem out :o
well worth a look
Post Tue Aug 02, 2011 7:40 pm
Alternatively: http://www.e30zone.net/e30zonewiki/inde ... per_faults in our own e30zone wiki.
Note that the method of removal of the scuttle grill is wrong in both links. You slide it downwards, against the pressure of the spring clips along the bottom to unhook the plastic tabs at the top, pull out the top and lift it away. No danger of damaging paintwork if done this way.
