Rav's Chromie, Bodywork time
Nice work Rav - many other morsels on this turd ? Whats wrong with it ?
turk
S54 would fit nicely in there mate ;)
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
Sump Baffles
TrackDays
Steve-E30
- East Sussex Hooligan
Rav335uk wrote: And the Chromie waiting patiently to be dumped in the lake
Giggety Giggety Goo!!!
- E30 Zone Meets/Events Team
Funny fooker Steve.
Rob, it was a light front ender on this one, everything else was working fine, engines fine too, had it running before we started to strip it
TPS
Rav, is that Sterling Silver? Whats the Bonnet like?
Yes Phil, but as I said, it had a front ender, bonnets no good at all.TPS wrote:Rav, is that Sterling Silver? Whats the Bonnet like?
TPS
Thanks mate, I'll keep looking!
PM'd RavRav335uk wrote:Funny fooker Steve.![]()
Will get back to you by Tuesday Rob, need to get back over there.
SpencerLavery
Not sure why people are so obsessed with an M30's weight, paired with their respective boxes the S50 actually weighs more than the M30. Tested on scales by my buddy.
ultralinear
If the box is what makes it heavier, then surely that weight is distributed further back?
I bet an M30 turbo would be fantastic
- Homo Hair
Both fully dressed?SpencerLavery wrote:Not sure why people are so obsessed with an M30's weight, paired with their respective boxes the S50 actually weighs more than the M30. Tested on scales by my buddy.
Which boxes?
I believe the S50 sits further back..
SpencerLavery
Both fully dressed yeah, the only thing I'm unsure of at the mo is whether it was a euro-spec S50 or a US-spec S50, will give him a buzz to ask.
I'd love to have the opportunity to weigh the same shell fitted with both motors on a 4 point scale, to check the distribution etc.
My point isn't to prove that the S50 is heavy though, it's to prove that the old anchor jokes are very much clutching at straws, and a bit tedious, considering a CF bonnet and lighter front alloys soon counteracts the weight difference even between an M52 and an M30.
M30 was weighed with a g260, S50 with the S5D320Z I believe.
M30/g260 was 540lbs. M20B27/g260 came up at 497lbs. I can't remember what the S50 came up at but it was 550lbs+ IIRC.
Just a quick google brings up the following, too:
Taken from here: http://www.unixnerd.demon.co.uk/enumber.html (assuming these are just blocks and heads)
M10 = 82kg = 184 lbs
M42 = 100kg = 220 lbs
S14 = 106kg = 233 lbs
M20 = 117kg = 257 lbs
M30 = 143kg = 315 lbs
M50 = 140kg = 308 lbs
S50 = 152kg = 334 lbs
Here's weight list from http://www.e30.de I assume that all the ancillaries are included in these weights.
M40B16 - 132kg
M20B27 - 175kg
M52B28 - 170kg
M50B25 - 198kg
M60B40 - 210kg
M30B35 - 212kg
M102 - 225kg
S38B36 - 232kg
M70B50 - 250kg
M40B16 - 132kg
M20B27 - 175kg
M52B28 - 170kg
M50B25 - 198kg
M60B40 - 210kg
M30B35 - 212kg
M102 - 225kg
S38B36 - 232kg
M70B50 - 250kg
retroboyo
The M30 would have a lower centre of gravity than a modern 4 valver too, as it's head would be lighter. With the ZR-1 they stuck with 2 valves for this very reason and it broke the Ring's production car record.
Yeah sure it would, great big fook off cast ally inlet propping the bonnet up and cast iron exhaust manifolds, vs plastic inlet and stainless tubular exhaust manisretroboyo wrote:The M30 would have a lower centre of gravity than a modern 4 valver too, as it's head would be lighter. With the ZR-1 they stuck with 2 valves for this very reason and it broke the Ring's production car record.
retroboyo
fair point, although they arnt obligatory on a M30
retroboyo
People make lightweight inlet manifolds eg
and stainless tubular exhaust manis are available for the m30
SpencerLavery
Lots of fun:ultralinear wrote:I bet an M30 turbo would be fantastic
At what cost????retroboyo wrote:People make lightweight inlet manifolds eg
That is not an inlet manifold BTW...
May I repeat a previous statement, 'you are clutching at straws'
These turned up today, not bad for £100 delivered.
SpencerLavery
For 2 i'm assuming? Where from? Need to order a set as some vw chap put superstretched on these alloys
Got them from ED38, hut had put them up for sale.
Although looking at Camskill they wer about £30 cheaper.
Got these today, Cheers Matt.
Lemforder ball joint bushes.
shiny bits ,your spoiling it,get the asthmatic donk out before you fall in love with economy !
+ a yard full of scrap turds
Economy isn't all it's made out to be with this 4 pot
These are the first, wishbones and the front 51mm struts are at the powdercoaters, rear beam will be next, subframe and front subframe, and also new front and rear wheel bearings
I totalled it up today, not cheap.
Jim320i
- E30 Zone News / COTM Team
Well worth it though Rav.
Should be Jim, need to have a good look at the body yet, so I can see an easy couple of £KKK thrwon at this chromie.
show me a cheap keeperRav335uk wrote:Economy isn't all it's made out to be with this 4 pot![]()
These are the first, wishbones and the front 51mm struts are at the powdercoaters, rear beam will be next, subframe and front subframe, and also new front and rear wheel bearings![]()
No can do, atleast i'm not paying for labour, I have full use of my mates garage, and 50 ton "OLD" press, the old balljoints came out like they were greased in
Totalling it up is for gays and skinflints, if you want a proper car you will get your wallet out
i've lost count and no longer care about the $ it's mine and that's all i wanted
edit typooo
edit typooo
This is a different ball game with me now mick, before it was buy what's needed, now it's save the money then buy what's "Really needed"
But so far loving it, totally different to the cab.
priority's 1st and the rest will come,Rome and a day or weekend for the record never happens .
subscribed
subscribed
Not now Dan, house comes first, then this.
Afew years ago, it wouldn't have been a problem.
kieran325
Like this Rav ?Rav335uk wrote:Economy isn't all it's made out to be with this 4 pot![]()
