Rav's Chromie, Bodywork time
Post Sat Jul 30, 2011 7:02 pm
Nice work Rav - many other morsels on this turd ? Whats wrong with it ? :D
turk
Post Sat Jul 30, 2011 7:11 pm
S54 would fit nicely in there mate ;)
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
Steve-E30
East Sussex Hooligan
Post Sat Jul 30, 2011 7:17 pm
Rav335uk wrote: And the Chromie waiting patiently to be dumped in the lake
:P
Giggety Giggety Goo!!!
Post Sat Jul 30, 2011 7:44 pm
Funny fooker Steve. :mad:
Rob, it was a light front ender on this one, everything else was working fine, engines fine too, had it running before we started to strip it :D
TPS
Post Sat Jul 30, 2011 8:06 pm
Rav, is that Sterling Silver? Whats the Bonnet like?
Post Sat Jul 30, 2011 8:36 pm
TPS wrote:Rav, is that Sterling Silver? Whats the Bonnet like?
Yes Phil, but as I said, it had a front ender, bonnets no good at all. :?
TPS
Post Sat Jul 30, 2011 8:38 pm
Thanks mate, I'll keep looking!
Post Sun Jul 31, 2011 8:57 am
Rav335uk wrote:Funny fooker Steve. :mad:
PM'd Rav :D
Post Sun Jul 31, 2011 11:27 am
Will get back to you by Tuesday Rob, need to get back over there.
SpencerLavery
Post Sun Jul 31, 2011 6:31 pm
Not sure why people are so obsessed with an M30's weight, paired with their respective boxes the S50 actually weighs more than the M30. Tested on scales by my buddy.
ultralinear
Post Sun Jul 31, 2011 7:15 pm
If the box is what makes it heavier, then surely that weight is distributed further back?
I bet an M30 turbo would be fantastic :rock:
Post Sun Jul 31, 2011 7:17 pm
SpencerLavery wrote:Not sure why people are so obsessed with an M30's weight, paired with their respective boxes the S50 actually weighs more than the M30. Tested on scales by my buddy.
Both fully dressed?
Which boxes?
I believe the S50 sits further back..
SpencerLavery
Post Sun Jul 31, 2011 7:25 pm
Both fully dressed yeah, the only thing I'm unsure of at the mo is whether it was a euro-spec S50 or a US-spec S50, will give him a buzz to ask.
I'd love to have the opportunity to weigh the same shell fitted with both motors on a 4 point scale, to check the distribution etc.
My point isn't to prove that the S50 is heavy though, it's to prove that the old anchor jokes are very much clutching at straws, and a bit tedious, considering a CF bonnet and lighter front alloys soon counteracts the weight difference even between an M52 and an M30.
M30 was weighed with a g260, S50 with the S5D320Z I believe.
M30/g260 was 540lbs. M20B27/g260 came up at 497lbs. I can't remember what the S50 came up at but it was 550lbs+ IIRC.
Just a quick google brings up the following, too:
Taken from here: http://www.unixnerd.demon.co.uk/enumber.html (assuming these are just blocks and heads)
M10 = 82kg = 184 lbs
M42 = 100kg = 220 lbs
S14 = 106kg = 233 lbs
M20 = 117kg = 257 lbs
M30 = 143kg = 315 lbs
M50 = 140kg = 308 lbs
S50 = 152kg = 334 lbs
Here's weight list from http://www.e30.de I assume that all the ancillaries are included in these weights.
M40B16 - 132kg
M20B27 - 175kg
M52B28 - 170kg
M50B25 - 198kg
M60B40 - 210kg
M30B35 - 212kg
M102 - 225kg
S38B36 - 232kg
M70B50 - 250kg
retroboyo
Post Sun Jul 31, 2011 8:29 pm
The M30 would have a lower centre of gravity than a modern 4 valver too, as it's head would be lighter. With the ZR-1 they stuck with 2 valves for this very reason and it broke the Ring's production car record.
Post Sun Jul 31, 2011 9:05 pm
retroboyo wrote:The M30 would have a lower centre of gravity than a modern 4 valver too, as it's head would be lighter. With the ZR-1 they stuck with 2 valves for this very reason and it broke the Ring's production car record.
Yeah sure it would, great big fook off cast ally inlet propping the bonnet up and cast iron exhaust manifolds, vs plastic inlet and stainless tubular exhaust manis :mad:
retroboyo
Post Sun Jul 31, 2011 9:42 pm
fair point, although they arnt obligatory on a M30
retroboyo
Post Sun Jul 31, 2011 10:16 pm
People make lightweight inlet manifolds eg
and stainless tubular exhaust manis are available for the m30
SpencerLavery
Post Sun Jul 31, 2011 10:18 pm
ultralinear wrote:I bet an M30 turbo would be fantastic :rock:
Lots of fun:
Post Sun Jul 31, 2011 10:48 pm
retroboyo wrote:People make lightweight inlet manifolds eg
At what cost????
That is not an inlet manifold BTW...
May I repeat a previous statement, 'you are clutching at straws' winkeye
Post Wed Aug 10, 2011 5:37 pm
These turned up today, not bad for £100 delivered. winkeye
SpencerLavery
Post Wed Aug 10, 2011 5:54 pm
For 2 i'm assuming? Where from? Need to order a set as some vw chap put superstretched on these alloys
Post Wed Aug 10, 2011 6:26 pm
Got them from ED38, hut had put them up for sale.
Although looking at Camskill they wer about £30 cheaper.
Post Fri Aug 12, 2011 9:19 pm
Got these today, Cheers Matt.
Lemforder ball joint bushes. :D
Post Fri Aug 12, 2011 9:24 pm
shiny bits ,your spoiling it,get the asthmatic donk out before you fall in love with economy !
winkeye
Post Fri Aug 12, 2011 9:26 pm
Economy isn't all it's made out to be with this 4 pot :mad:
These are the first, wishbones and the front 51mm struts are at the powdercoaters, rear beam will be next, subframe and front subframe, and also new front and rear wheel bearings 8O
I totalled it up today, not cheap.
Jim320i
E30 Zone News / COTM Team
Post Fri Aug 12, 2011 9:28 pm
Well worth it though Rav. :cool:
Post Fri Aug 12, 2011 9:31 pm
Should be Jim, need to have a good look at the body yet, so I can see an easy couple of £KKK thrwon at this chromie. :mad:
Rav335uk wrote:Economy isn't all it's made out to be with this 4 pot :mad:
show me a cheap keeper :mad:
Post Fri Aug 12, 2011 9:34 pm
No can do, atleast i'm not paying for labour, I have full use of my mates garage, and 50 ton "OLD" press, the old balljoints came out like they were greased in :mad:
Post Fri Aug 12, 2011 9:36 pm
Totalling it up is for gays and skinflints, if you want a proper car you will get your wallet out :)
Post Fri Aug 12, 2011 9:38 pm
i've lost count and no longer care about the $ it's mine and that's all i wanted :D
edit typooo :mad:
Post Fri Aug 12, 2011 9:41 pm
This is a different ball game with me now mick, before it was buy what's needed, now it's save the money then buy what's "Really needed" :?
But so far loving it, totally different to the cab. :D
Post Fri Aug 12, 2011 9:44 pm
priority's 1st and the rest will come,Rome and a day or weekend for the record never happens .
subscribed :D
Post Fri Aug 12, 2011 10:02 pm
Not now Dan, house comes first, then this.
Afew years ago, it wouldn't have been a problem. :(
kieran325
Post Sat Aug 13, 2011 9:44 am
Like this Rav ?
winkeye
