EDC (Electronic Damper Control)
cliff_costa
What makes you think it has eds
- **BANNED**
Fuse 20/21 and their rating and use is shown here;
http://www.e30zone.net/e30zonewiki/index.php/Fuse_Box
and EDC is not mentioned at all.
Youth is wasted on the young.
rrs
If I'm not mistaken that is a cable to the abs sensor on that hub, it is usually attached the the strut via a couple of brackets with push in rubber grommets.diable wrote:This cable runs through the bodywork to the damper I believe, will take wheel off over the weekend to confirm. I am just wondering if I am totally barking up the wrong tree.........
- **BANNED**
Photo shows the ABS sensor connector.
The gadget in the boot is the ECU for your switchable auto box.
At a rough guess,a previous owner has added a second(perhaps replacement)control to the centre console.
I have NEVER seen or heard of a non M3 with EDC. My guess is some council type wanted to impress his mates by fitting an extra knob
HairyScreech
have you checked if your knob actually works?
if you twist it does it feel any stiffer?
Takes five minutes to lift the rear console and see if there's any wiring connected to the switch. A single 10mm nut under the rear ashtray holds it in place.pacerpete wrote:I have NEVER seen or heard of a non M3 with EDC. My guess is some council type wanted to impress his mates by fitting an extra knob
Surely the quickest and easiest way to tell if EDC is fitted is to stick your head under the back of the car and look at the rear dampers ? - No dismantling of anything required !
diable wrote:@Pacer, I'd be surprised if it was that as its a well looked after and tidy car, apart from the wiring to the sub in the boot ;o))
@Hairy, the knob is fairly free moving but you can feel that its a 3 position switch.
@Brian, if the weather is ok over the weekend I'll be lifting out the center console to see whats underneath, maybe I was just hoping that it had it fitted and let my imagination run wild.
Will post back after the weekend.
EDC is NOT something you want on a 20 year old car . It was of dubious benefit even when it was new , now it is a load of 20 year old frag waiting to expire, expensively.
Morat
sniggerHairyScreech wrote:have you checked if your knob actually works?
e301988325i
Gentlemans bet it's been bodged in for turning the sub amp on/offdiable wrote: apart from the wiring to the sub in the boot ;o))
I said:
e30topless said:
lock the wife in there
that's ABS innitdiable wrote:One that diagram is states fuse 21 and 26 and they are in place, I'd be buggered if I new where it is fused.
I may have a couple of photos and will post them up in a moment.
Not decent enough quality, will take some more over the weekend.
