Beemerlad's M52 Chromie
Post Fri Jul 08, 2011 10:36 pm
Lee, bit of a long shot but have you tried adjusting the brake bar that links the pedal box to the rear of the servo ?
Post Fri Jul 08, 2011 11:07 pm
e30topless wrote:Lee, bit of a long shot but have you tried adjusting the brake bar that links the pedal box to the rear of the servo ?
No mate, I may have a play in the morning and see if it makes any difference, but I want to give it a half decent road test, like a 10 mile blat to check they don't heat up
billgatese30
Post Fri Jul 08, 2011 11:15 pm
shame I am carting our Kid to York with the trailer on otherwise I could have offered a lift but I'm getting him there and dumping him for 3pm before heading down to the pod and then I'll be picking him up on the way back so the van will be full to the brim as it is. unless you don't mind hanging about its better than being totally stuck dude, I'm sure I can work something though if you are desperate.
Post Fri Jul 08, 2011 11:26 pm
Set your alarm for 5am! I am and im only cleaning the coont :mad:
Andyboy
Alpina Colada
Post Fri Jul 08, 2011 11:45 pm
It's got to be this. Drop the column undertray and the glovebox down, 17mm and a pair of locking pliers to set the pedal height. It's also worth taking both clevis pins out and making sure the brake pedal isn't seizing. Also make sure the pedal return spring is there - if it's not, the brakes will not return fully, drag on and overheat after a few miles. If in doubt, add an extra spring to make really sure.
Bleed the brakes out again, and make sure the pedal sinks down easily - if it feels hard, it could be the front flexies healing up inside. But the pedal/cross link is my guess.
Post Fri Jul 08, 2011 11:51 pm
wasn't the previously M10 powered Beast sporting a spazbox Lee ?
maybe the manual pedal box was never quite set up, it takes a bit of fine tuning to get it just right,
gimme a bell if you get stuck :)
Post Fri Jul 08, 2011 11:57 pm
She was a manual in her previous life.
The pedal springs back fine, but I'l molest the bar in the morning and check.I've come to like the drunk passenger idea though :)
Everett, have you still got that little tent you used last year? Just checking you have accomodation
Andyboy
Alpina Colada
Post Sat Jul 09, 2011 7:52 am
I've still got the Tent of Doom from last year Chief - it's seen a bit of use since then. Pack it away carefully? Do I bollocks - just roll it up into a ball and shove it into a box/bag.
Kwalitay.
Post Sat Jul 09, 2011 7:56 am
This is what you need -
Dezzy
CR24v it's a lifestyle
Post Sat Jul 09, 2011 8:04 am
Thats the t1ts^^
Post Sat Jul 23, 2011 1:22 am
Going to hopefully sort the brakes this weekend.
Then it's going to be vanos seals time.
Dan, do I just need the single gasket for the top front timing gear cover when doing these seals?
Dezzy
Post Sat Jul 23, 2011 9:35 am
Get it sorted matey :D
Post Sat Jul 23, 2011 4:27 pm
Vanos unit gasket and maybe cam cover gasket 8)
Post Sat Jul 23, 2011 5:49 pm
Fitted a spoilerless bootlid today, looks alright.
Bled the brakes and still a wank pedal, so am going to have to pull the master cylinder and servo off tomorrow and see where we are at. What an arse.
Dezzy
Post Sat Jul 23, 2011 6:10 pm
Maybe try the rod first. See how much travel it'll take up?
Post Sat Jul 23, 2011 8:30 pm
Yeah, I'll give the rod a tickle, but I don't think it will take up enough slack mate.
IIRC I wound the nut on the end of the servo push rod right in, so there's a few mm to be had there if that's where the problem is. Maybe the spacer moved further into the master cylinder when i first jabbed the brakes?
Post Sun Jul 24, 2011 4:22 pm
Had the lot off today, master cylinder, servo etc. Checked I was happy with the length of the servo rod etc. Put it all back together, bled the brakes off again. Pedal is better but still not what it should be, sick of the cooont.
If I decide to dig the wilwoods out the garage, do I need to go up to a bigger master cylinder?
I'm going to persevere with this a bit longer, but the lure of a certain E28 is strong.
Post Sun Jul 24, 2011 7:43 pm
Just pull the MC forward and wind the push rod out a turn or two at a time until your happy with the pedal
Post Mon Jul 25, 2011 1:19 pm
Yeah I'll give that a shot mate.
I was nervous of doing that though as I thought I'd then end up with the brakes sticking on again.
I did this to some extent yesterday when I had the m/c and servo separated and when I had wound the servo push rod out a couple of turns, when I pushed the m/c onto the servo it pushed fluid out the ports on the last 4-5mm of travel before the m/c was flush with the servo. So I wound it back out so there was probably about 1mm gap between servo & m/c when pushing them back together before I could feel it resisting slightly.
What do you reckon this turd will frag for? :D
Post Fri Jul 29, 2011 1:35 pm
Lots of naughty plans being hatched for this turd at the minute, more to follow :)
320Touring
Post Fri Jul 29, 2011 2:13 pm
E30BeemerLad wrote:Lots of naughty plans being hatched for this turd at the minute, more to follow :)
Whipround for a gallon of optimax? winkeye
Seriously though, she's a nice old turd, and did you proud at the York dragway- keep her, eh!
Post Fri Jul 29, 2011 2:34 pm
She'll be getting kept, but will be undergoing a "transformation" later in the year.
ultralinear
Post Fri Jul 29, 2011 3:02 pm
Intrigued...
Post Fri Jul 29, 2011 3:56 pm
He's finally seen the light and going M30 :D
ultralinear
Post Fri Jul 29, 2011 4:12 pm
Yeah, Lee was pissing about in the loft when a shelf collapsed and his collection of bowling balls bounced of his head one by one. Then he fell out of the loft and cascaded down the stairs... coming to rest by the front door. His missus came home from work and couldn't figure out why the front door wouldn't open, no matter how hard she struck the door against whatever object was blocking the way. After 5 minutes of this, Lee 'saw the light' and decided putting an M30 in his chromie was a great idea :mad:
Post Fri Jul 29, 2011 4:16 pm
Sorry to disappoint Ravstar, but no M30 donk is going near my chariot.
It will still have 24 valves. So I will still qualify for CR24v status
But there is going to be some serious shizzle going down I tells ye.
Topblag
Post Fri Jul 29, 2011 4:20 pm
It'll have that much snizzle, it'll end up on the televizzle. :cool:
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
ultralinear
Post Fri Jul 29, 2011 4:41 pm
So S50 or turbo, or supercharger :cool:
Post Fri Jul 29, 2011 4:44 pm
Not M50,M52 or S50
Post Fri Jul 29, 2011 4:46 pm
You're going Jap, ain't ya! :mad:
Cook318IS
Post Fri Jul 29, 2011 4:52 pm
It has to be that v12 engine you have knocking about?
Post Fri Jul 29, 2011 4:57 pm
Yep, V12, floor removed, spaceframe on ladder type bottom end, bulkhead cut away and engine shoved right back, full cage, sheet steel floor, not sure on the rear end yet.
Car is unlikely to be road legal again but it could be possible. Will retain OEM external appearance though.
Oh and a big naughty shot of gas for the drag strip.
So M52 conversion will be for sale later in the year along with M3 interior and anything else not needed.
Cook318IS
Post Fri Jul 29, 2011 5:00 pm
Woooot :D This is going to be epic :D (What do i win for guessing it right?)
Dezzy
Post Fri Jul 29, 2011 5:10 pm
100 pages already and here we go again.
It just so happens there's a cage here brother. winkeye
Post Fri Jul 29, 2011 5:11 pm
So how long will this swap take....? :) winkeye
