Under-dash panel
Ranchero
Are the clips used all the same? Those little black fasteners that need to be turned 90 degrees to stay in place.
There are 3 in a line under the steering wheel and 1 a little further down.
Then there is another hole near to the pedals. That's the one I'm wondering about as the clip is missing.
Lethal. I hate that poxy cardboard panel almost as much as it seems to hate me.
polsta
pain in the arse them panels i know how you feel, had aggro with the one in my is, bought a nice one..i dropped it in my garage once and it broke the corner off, got another, and put that in
i buy a sport, and suprise suprise it had a facelift one in so i need yet another one
and i think ? its just 3 clips at the top, dont remember being a lower one ?
Ranchero
There has to be one near the pedals. It flopped down and gripped my ankles as I was driving back from the shops earlier. Like something out of Christine, or a particularly spiteful Herbie.
polsta
there is a 3 pronged metal clip to the right that holds it, and on the left side, it slides inside the holder on the round column bit ?
Ranchero
Cheers. I'll have another look.
DHFiS
Right above the pedals there is a 3 prong slot, then one fastening up under the steering column and 3 across the top edge.
adit
the pedal board is secured by the three plastic screws/fasteners along the top edge, plus one larger one in the centre, and slots into the three prong bracket on the bulkhead, above the acc pedal and a plastic clip which fits round the bottom of the steering column
[quote="bss325i"]
mattycoops43
Mine attacked me a while back so I kicked it really hard while driving and it hasn't come back down yet after 3 months!
1990 325i se "weinrot"-How did they know?
Ranchero
Sorted
. Much better now. The panel that was there previously had the lower half removed.
- **BANNED**
I learn something every day on the zone,I have yet to see the 'larger one in the centre'!adit wrote:the pedal board is secured by the three plastic screws/fasteners along the top edge, plus one larger one in the centre, and slots into the three prong bracket on the bulkhead, above the acc pedal and a plastic clip which fits round the bottom of the steering column
Although I have seen panels with a hole in this sort of place,is this a prefacelift thing?
On both of my current cars,I have bodged a panel from cars that had headlight adjusters by filling the hole for the adjuster,then covering the entire panel with black vynl over a layer of thin foam.
Youth is wasted on the young.
Ranchero
I doubt it. I've taken the panel from my facelift 320i to replace that on my 318is.daimlerman wrote:,is this a prefacelift thing?
The old panel has a slit in the same place as its replacement and there is a hole below the steering column to accept the clip.
I suspect the clips have a tendency to work loose and fall off.
Morat
After being attacked by mine I've decided to leave it off. Unless they're 100% secured they're dangerous and mine was held in by woodscrews (!) so there's not much left to secure the top end to now even if I find a pristine replacement.
bpowell555
The large pin in the centre is the same as the ones that hold the panel on behind the headlights
1990 325i touring
She's a minter! Best 3 years of my life - bye bye baby
Ranchero
No, it's smaller. The 'shaft' is the same size as the ones that go in line below the steering wheel whereas the 'head' is slightly wider than those. It's a very fine distinction.
That panel is a rubbish component in any case.
bpowell555
Mine has been solid as since I took the plug off the headlight cover.. your mileage may vary
1990 325i touring
polsta
never seen /known about the clip in the middle
