Under-dash panel
Ranchero
Post Fri Jul 08, 2011 6:10 pm
Are the clips used all the same? Those little black fasteners that need to be turned 90 degrees to stay in place.
There are 3 in a line under the steering wheel and 1 a little further down.
Then there is another hole near to the pedals. That's the one I'm wondering about as the clip is missing.
Lethal. I hate that poxy cardboard panel almost as much as it seems to hate me.
polsta
Post Fri Jul 08, 2011 6:22 pm
pain in the arse them panels i know how you feel, had aggro with the one in my is, bought a nice one..i dropped it in my garage once and it broke the corner off, got another, and put that in
i buy a sport, and suprise suprise it had a facelift one in so i need yet another one
and i think ? its just 3 clips at the top, dont remember being a lower one ?
Ranchero
Post Fri Jul 08, 2011 6:27 pm
There has to be one near the pedals. It flopped down and gripped my ankles as I was driving back from the shops earlier. Like something out of Christine, or a particularly spiteful Herbie.
polsta
Post Fri Jul 08, 2011 6:32 pm
there is a 3 pronged metal clip to the right that holds it, and on the left side, it slides inside the holder on the round column bit ?
Ranchero
Post Fri Jul 08, 2011 6:33 pm
Cheers. I'll have another look.
DHFiS
Post Fri Jul 08, 2011 9:03 pm
Right above the pedals there is a 3 prong slot, then one fastening up under the steering column and 3 across the top edge.
adit
Post Fri Jul 08, 2011 10:57 pm
the pedal board is secured by the three plastic screws/fasteners along the top edge, plus one larger one in the centre, and slots into the three prong bracket on the bulkhead, above the acc pedal and a plastic clip which fits round the bottom of the steering column
[quote="bss325i"]
mattycoops43
Post Fri Jul 08, 2011 11:16 pm
Mine attacked me a while back so I kicked it really hard while driving and it hasn't come back down yet after 3 months! :cool:
1990 325i se "weinrot"-How did they know?
Ranchero
Post Sat Jul 09, 2011 2:01 pm
Sorted :thumb: . Much better now. The panel that was there previously had the lower half removed.
**BANNED**
Post Sat Jul 09, 2011 7:13 pm
adit wrote:the pedal board is secured by the three plastic screws/fasteners along the top edge, plus one larger one in the centre, and slots into the three prong bracket on the bulkhead, above the acc pedal and a plastic clip which fits round the bottom of the steering column
I learn something every day on the zone,I have yet to see the 'larger one in the centre'!
Although I have seen panels with a hole in this sort of place,is this a prefacelift thing?
On both of my current cars,I have bodged a panel from cars that had headlight adjusters by filling the hole for the adjuster,then covering the entire panel with black vynl over a layer of thin foam.
Youth is wasted on the young.
Ranchero
Post Sat Jul 09, 2011 7:19 pm
daimlerman wrote:,is this a prefacelift thing?
I doubt it. I've taken the panel from my facelift 320i to replace that on my 318is.
The old panel has a slit in the same place as its replacement and there is a hole below the steering column to accept the clip.
I suspect the clips have a tendency to work loose and fall off.
Morat
Post Sat Jul 09, 2011 9:18 pm
After being attacked by mine I've decided to leave it off. Unless they're 100% secured they're dangerous and mine was held in by woodscrews (!) so there's not much left to secure the top end to now even if I find a pristine replacement.
bpowell555
Post Sun Jul 10, 2011 12:39 am
The large pin in the centre is the same as the ones that hold the panel on behind the headlights :)
1990 325i touring
She's a minter! Best 3 years of my life - bye bye baby :D
Ranchero
Post Sun Jul 10, 2011 12:46 am
No, it's smaller. The 'shaft' is the same size as the ones that go in line below the steering wheel whereas the 'head' is slightly wider than those. It's a very fine distinction.
That panel is a rubbish component in any case.
bpowell555
Post Sun Jul 10, 2011 12:03 pm
Mine has been solid as since I took the plug off the headlight cover.. your mileage may vary :cool:
1990 325i touring
polsta
Post Sun Jul 10, 2011 12:09 pm
never seen /known about the clip in the middle
