my car is not as responsive in 3rd gear as i would like?
miami325e
Post Tue Nov 01, 2005 5:42 pm
what can i do to make that better. i floor it in third and it takes a secondor two to respond, like turbo lag?. i would like it to respond like it does in second gear. a lot quicker.
could it be my throttle adjustment?i have to adjust full throttle stop under gas pedal and throttle butterfly
bad wires,dist. cap , dist rotor?
bad fuel pressure regulator?
valves out of tuning? then why does it respond in second
could i have a burnt valve?
or could i have a computer problem? replace ecu
is my car just made like this?slow?
maybe i need to adjust air flow? check maf
bad injectors?
is the problem fuel delivery,air delivery or just some electronic fault or mechanical adjustment or fault.
if i buy a jc chip will it help?
thanks
Demlotcrew
Post Tue Nov 01, 2005 5:44 pm
Its very hard to say whats wrong without changing everything you have mentioned above!
I would look at rubber hoses, air gaskets, electricals (cap + rotor + plugs)
Andrew
Luke
Post Tue Nov 01, 2005 6:03 pm
have you considered the gear ratios? sports pull harder in third than those with normal boxes like mine - it's noticeably less responsive in third. Still pretty damn quick though!
1990 325i SE
Fushion_Julz
Post Tue Nov 01, 2005 6:51 pm
If I were you, chap, I'd be looking for a car witout an eta motor and slush box...not to mention a diff with a lower ratio!
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
