Beemerlad's M52 Chromie
Duke137
Post Fri Jul 01, 2011 8:45 am
Dezzy wrote:
DanThe wrote:How would you know? The rules are unwritten :wink:
Unspoken too! 8O
The first rule of CR24v is you do not talk about CR24v :?: :?
Post Fri Jul 01, 2011 10:08 am
drove the car into work this morning and no sticking brakes, WTF! :?
Going to take a look though as it's stupid to assume it will behave on a 150 mile journey to the pod without ruining mine and others weekends.
Dezzy
CR24v it's a lifestyle
Post Fri Jul 01, 2011 11:34 am
You've had nowt but chew with the brake set up have you mate! :(
Post Fri Jul 01, 2011 11:37 am
Indeed, and this is before I contemplate messing about fitting the wilwoods which have been gathering dust in my gargae for 18 months
Dezzy
Post Fri Jul 01, 2011 11:43 am
I don't get it mate. Is it not just a dodgy caliper?
Duke137
Post Fri Jul 01, 2011 11:51 am
Come on Lee fit them wilwoods man, makes sense now 8)
e30-EVN
Post Fri Jul 01, 2011 12:07 pm
does sound like a sticky calliper if its intermitant tbh...... good excuse to fit the wilwoods though lee winkeye
get it done son lol :D
Post Fri Jul 01, 2011 2:10 pm
the wilwoods need some new seals, plus I don't yet have the 280mm discs, the spacer or the earls lines needed.
I don't think it is a sticky caliper is both fronts were red hot and it is unlikely 2 front calipers would both get stuck simultaneously, well that's my view anyway
Post Fri Jul 01, 2011 2:13 pm
Servo pushrod?
Post Fri Jul 01, 2011 2:16 pm
Did you change the MC from last time? Or is it still the one that locked the rears up?
Post Fri Jul 01, 2011 4:40 pm
same m/c.
All I did to alleviate the rears cooking themselves was chop about 5mm from the end of the servo push rod (i have no spacer either). it has been fine for probaby 2000 miles until last night.
Post Fri Jul 01, 2011 7:04 pm
The front brakes should always come on first as the piston moves forward in the MC
Maybe something is sticking in the servo/brake bar linkage or MC
Post Fri Jul 01, 2011 8:16 pm
Drove home tonight and after a few miles they started sticking on. So i pulled the bonnet up when i got in and loosened the master cylinder by giving the nuts a couple of turns, started to hear the vacum leak a little.
Went out and did a couple of miles and they didn't stick on any more.
May have to pull the lot off and have a closer look as the method used so far is a bit of a bodge, even by my standards :)
Post Mon Jul 04, 2011 6:30 pm
Drove it again just now, brakes still stuck on after about 2 miles, even with the master cylinder loosened off.
So sick of this turd, I really am.
E30Gheko
Post Mon Jul 04, 2011 6:32 pm
Stick with it Lee. Far too much time invested to give up now. U'll get it sorted. If it's doin ur head in go and play on the xbox for a bit and go back to it. 8)
[youtube][/youtube]
:giggle:
appletree
Post Mon Jul 04, 2011 9:22 pm
Have you ajusted the bar that goes from the pedal to the pas side of the car? forgot the real name :?
Topblag
Post Mon Jul 04, 2011 9:29 pm
appletree wrote:Have you ajusted the bar that goes from the pedal to the pas side of the car? forgot the real name :?
The brake bar ? :mad:
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
monkey
Post Mon Jul 04, 2011 9:39 pm
on mine i am using the Renault master cylinder that goes with the Renault servo that i'm using . i had to change one of the pipes as the Renault one uses a larger union on one pipe . but the brakes now work much better than they did with e30 master and clio servo :)
leeparkes
Post Mon Jul 04, 2011 9:45 pm
Id put money on it being a duff master Lee, i had the same trouble last month.
http://www.e30zone.net/modules.php?name ... 59&start=0
Post Tue Jul 05, 2011 8:54 pm
Master cylinder on the way, pulled the old one off tonight, replacement should be here thursday so I'll hopefully get on that thurs night and be able to do a little road test to see if it cures the problem.
If it doesn't sort it then the turd will be staying at home and i'll be riding shotgun with Dez
Andyboy
Alpina Colada
Post Wed Jul 06, 2011 9:36 pm
I would also adjust the cross linkage to give more pedal free travel - I'd almost put money on that curing the problem.
Post Thu Jul 07, 2011 9:17 pm
Swapped in the replacement master cylinder tonight, but discovered I did have a spacer in my old master cylinder after all :mad: but it was stuck, so I had to knock up another spacer and thought I would take some pics to help others.
Please note that the length of spacer tends to vary slightly on each car.
I made this one out of one of the clips that fastens the gear level cradle to the top of the gearbox, hacked the clevis part off, lovely snug fit into the master cylinder
Master cylinder without the spacer in
Showing it in place, I drilled out a little countersink in the end of it for the servo push rod to face into nicely
I test fitted it upto the servo and could feel it push/resist a bit just before the m/c fitted flush upto the servo, so I drilled a bigger recess out the end and it fitted up with no final resistance
So the master cylinder is all bolted up and plumbed back in, but I can't find my damn eazibleed thing, so work has stopped :-x
Been around and checked all the bleed nipples and they all loosen off. So i'll buy an eazibleed at lunchtime tomorrow and will have to bleed the cooont tomorrow night after work.
Always down to the wire with the pod :)
Dezzy
Post Thu Jul 07, 2011 9:19 pm
Lee you can't find it because its here :o:
I saw it today in a tesco bag. I didnt even know i had it. I can't even why its here :?
Post Thu Jul 07, 2011 9:23 pm
I thought tonight whilst I was throwing and kicking stuff around the garage, "i'm sure I leant it out to someone, but who?" :)
I think took it up there when me & Everett came up, it was either to do brakes or clutch slave I can't remember. Maybe I gave you it earlier, too much green :)
Dezzy
Post Thu Jul 07, 2011 9:26 pm
Your post made me realise who's it was mate.
I wasasking about today who's it was at work :D
I bring it on saturday 8)
Post Thu Jul 07, 2011 9:29 pm
Keep it or bin it mate, I'll have a new one tomorrow :D
Dezzy
Post Thu Jul 07, 2011 9:33 pm
I hope your sorted now mate.
I am well looking forward to Saturdays adventure's now winkeye
Post Thu Jul 07, 2011 9:41 pm
Wow, this is page 100 of my 24v adventure, this will be the 3rd pod outing for the M52 engine, once in the touring and 2nd visit in the chromie (providing the brakes are sorted).
Even if the brakes are fubar, at least I'll be going there in 24v power :)
Saturday should be good crack mate
Post Thu Jul 07, 2011 9:45 pm
I knew you couldnt be running a clio servo without a spacer :D
As for bleeding, take the calipers off and push the pistons in, job done :wink:
Post Thu Jul 07, 2011 11:32 pm
Dan you smart f'ker, nice one
Post Fri Jul 08, 2011 7:04 pm
Utterly pishing it down here, thunder the works, fingers crossed I can get these brakes bled :-x
Post Fri Jul 08, 2011 9:33 pm
OK my car isn't coming to the pod.
Wound all 4 caliper back and it filled the reservoir to the brim, but I'm not getting brakes until the pedal has travelled about 4 inches. It's getting dark and I'm not going to ponce about in the morning hoping for the best and then ruin other people's day with hard shoulder dramas.
I don't know if it's air in the system or the spacer in the master cylinder or god knows what else.
Dez, looks like you've got a passenger :(
Dezzy
Post Fri Jul 08, 2011 9:37 pm
No problem mate.
Lets hope mine is ok :eek:
Post Fri Jul 08, 2011 10:28 pm
Bad news Lee, thought it would have been ok replacing the master.
Dezzy, you covering your passenger seat :mad:
Dezzy
Post Fri Jul 08, 2011 10:30 pm
What for? Rock burns?!
