Dyno testing results
mattqf77
Sat May 28, 2011 12:17 am
Just had my car dyno tested - Max 166.1 HP. Not bad for E30 M20 325i Touring 1989' considering engine is completely standard...
146,000 miles - head rebuilt at 110,00 miles.
Touring
gaszman
Sat May 28, 2011 8:47 am
well done mine was 163.0hp 186000 miles on the bad boy
charlE30
Sat May 28, 2011 9:51 am
Both impressive given how old these are getting now 8)
BMW F31 335d xdrive
oguz327
Captain Armco
Captain Armco
Sat May 28, 2011 1:29 pm
227.5 bhp for mine last time it was on the rollers, and still does just under 500 miles to a tank on the run.
Not bad for a small boat anchor with Mega Squirt :D
mattqf77
Sat May 28, 2011 3:22 pm
Is mega squirt system similar to MAF conversion. Is that the only mod you have done. impressive Bhp and fuel economy
Touring
mattqf77
Sun Jun 19, 2011 12:39 am
I've also had a dyno test run done with Speedtouch Mild eco torque chip - Max 164.3 bhp
This was just done as a comparison..
Touring
beba
Sun Jun 19, 2011 1:07 am
mattqf77 wrote:I've also had a dyno test run done with Speedtouch Mild eco torque chip - Max 164.3 bhp
so you lost 2bhp using a chip? did you gain any torque though?
Motorhole
Sun Jun 19, 2011 10:52 am
mattqf77 wrote:Is mega squirt system similar to MAF conversion. Is that the only mod you have done. impressive Bhp and fuel economy
Nope! Megasquirt is a standalone programmable ECU that comes in kit form :)
mattqf77
Sun Jun 19, 2011 12:07 pm
No gain in torque either - Max 163.9 HP
Standard BMW chip :
Max 166.1 HP - BHP
Max 165.2 HP - Torque
Max 165.1 HP - Flywheel
Speedtouch Eco Torque chip B25M20 :
Max 164.3 HP - BHP
Max 163.9 HP - Torque
Max 162.9 HP - Flywheel
There was increase in torque surge between 2000 - 2500 RPM peaking then drops back to that of standard. Maybe explaining feeling of increase in mid range torque.
Will scan dyno chart
Touring
Sun Jun 19, 2011 12:37 pm
so a waste of money like 90% of chips then.
adamski80
Sun Jun 19, 2011 12:45 pm
Just picked mine up from Circuit motors. M20 2.5
190 bhp and 167 torque. Thought torque would be higher but impressed anyway
Cook318IS
Sun Jun 19, 2011 12:51 pm
Not quite the same but on the speedtouch chip i had fitted to my m50 it made less bhp + torque than it did on the standard chip. But it did seem quicker somehow, and the 7krpm limit was awesome.
Does it feel faster to drive with the chip in?
mattqf77
Sun Jun 19, 2011 1:04 pm
Feels bit faster from stand still - not impressed by dyno result though
Touring
