Bonnet release - help!
Cyman
Wed Jun 15, 2011 8:40 pm
Hi,
Some muppet just reversed into the front of my car =(
The kidney grill is pushed in and one edge of it has cracked, but that is the only visible damage.
However, the bonnet was also pushed in a tiny bit....(you really can't tell), and the release cable is now loose, which means I can no longer open the bonnet.
Is there a way to release the bonnet catch from outside? I'm guessing it's just behind the front grill. Maybe if I pulled the grill out and went at it with a screwdriver?
Any suggestions welcome!
Cheers,
Simon
bimanut
Wed Jun 15, 2011 8:52 pm
Yes you can open it from the front,as you say get a screw driver and there is a little hole somewhere in the mechanism that you can pop it open.
Couldnt give a propor location but it is there i`ve had to do it myself when the cable snapped
**BANNED**
Wed Jun 15, 2011 8:54 pm
Behind the n/s front grille.
Youth is wasted on the young.
Cyman
Wed Jun 15, 2011 9:16 pm
So...
"A little hole somewhere in the mechanism behind the n/s front grille that you can pop it open".
Will have a crack at it over the weekend.
Thanks for the advice!
Cyman
Thu Jun 16, 2011 10:03 pm
Found the hole, popped the bonnet, discovered that the release cable was loose due to a missing nut holding the release handle to the wall of the passenger footwell.
1 rawlplug & 1 screw later...job done =)
Thanks for the help!
Now to find a new grill...
Thu Jun 16, 2011 11:32 pm
Rawlplug??????????????????
Morat
Fri Jun 17, 2011 7:57 am
Maybe he has already dry-lined the footwell because it was damp? :)
