Lee Parkes' E30 Alpina B10.
Duke137
Post Tue May 24, 2011 9:18 pm
Sounds a job well done :D
leeparkes
Post Tue May 24, 2011 9:23 pm
Cheers for the comments bruv's :D
Body work is next :(
zaust
Zone day release
Post Tue May 24, 2011 9:34 pm
Nice one, What diff you running now ?
M30 Tech 1 Touring on gas.
Post Tue May 24, 2011 10:13 pm
leeparkes
Post Tue May 24, 2011 10:36 pm
Im still running a 3.73 slipper which is a tad short even for a standard M30.
staley_turbo
Post Wed May 25, 2011 10:16 am
leeparkes wrote:Im still running a 3.73 slipper which is a tad short even for a standard M30.
Not as short as the 3.9 i have in at the min! What do you plan on using? Ive been looking for a 3.1 but not sure if that will be too long?
leeparkes
Post Wed May 25, 2011 6:09 pm
Im swaying towards a 3.46, if your running over 300hp id be aiming for a 3.25 or maybe a 3.15.
Ive done a compression test on the lump today :)
All in fine form with pressure ranging around the 11.5 bar mark 8)
zaust
Zone day release
Post Wed May 25, 2011 6:59 pm
I know of 2x 3:46 lsd's and one small case 3:25 lsd. All around the £400 mark but from a good source.
I'm on a 3:46 slipper and I think it's the perfect balance between drifting and going well. With a turbo it would have to be 3:25 or 3:15 all day.
Post Wed May 25, 2011 7:06 pm
I actually find my 3.46 abit lazy round town, but perfecto on the motorway, but i'm changing to a 3.64 in a few weeks
leeparkes
Post Wed May 25, 2011 11:16 pm
zaust wrote:I know of 2x 3:46 lsd's and one small case 3:25 lsd. All around the £400 mark but from a good source.
Small case 3:25, what did that come off?
zaust
Zone day release
Post Fri May 27, 2011 11:48 pm
323 hartage with dog leg.
leeparkes
Post Thu Jun 02, 2011 7:54 pm
zaust
Zone day release
Post Fri Jun 03, 2011 12:23 am
Not good new's, hope you find it soon.
E30SPORTMAD
Post Fri Jun 03, 2011 12:50 am
You will get it sorted Lee soon enough, Lovely E30 btw
leeparkes
Post Sun Jun 05, 2011 3:54 pm
Brakes all sorted 8)
With that done ive been out for a 40 mile blast, fook me its quick and a right handfull to keep in a straight line, it doesnt accelerate it Charges :twisted:
All this fun didnt last long though :(
All of a sudden the temp gauge was on the 3/4 mark, fan on and blower on but it still wouldnt cool down. I limped it home with the bonnet popped with both blowers on.
Main suspect was the stat, so when i got home i opened it up and found this :?
Can you see the cracked bit in the middle?
Im trying to think how old this stat is, ive gone through my thread and cant find when it was new but iirc i brought it when i first done the swap two years ago.
New stat on order tomorrow 8)
Cypriotgeeza
Post Sun Jun 05, 2011 5:43 pm
Check my M30 build threads:
leeparkes
Post Wed Jun 15, 2011 11:35 pm
My Land rover V8 engine mounts turned up today 8)
The standard M20 ones were due a change anyway, they wasn't squashed but if i grabbed the engine i could rock it side to side a bit too much.
Its like its on blocks of wood now :D
Here they are.
They are slightly smaller in height than the M20 one's. LR ones are 37mm M20 ones are 45mm.
Here they are compared to each other.
Got a couple of 7mm spacers and jobs a good un.
Fitted.
There is quite a bit of clearance between the rack and sump so may be able to lose some mm of the spacer to get the engine lower down 8)
staley_turbo
Post Thu Jun 16, 2011 8:33 am
What improvement do these make? Im looking for some harder mounts.
walinsky
Post Thu Jun 16, 2011 5:23 pm
staley_turbo wrote:What improvement do these make? Im looking for some harder mounts.
I bought these
from
(do not click these links if you're afraid ze Germans will hurt your eyes)
->wuddelcrew<-
on
->e30-talk.com<-
They're harder than original mounts; 75mm x 50mm and specifically meant for m30 swaps.
leeparkes
Post Thu Jun 16, 2011 9:06 pm
There just stronger buddy with less 'give' in them with no extra vibration.
Under a tenner for the pair delivered too :)
zaust
Zone day release
Post Thu Jun 16, 2011 9:24 pm
I'm likeing the look's of these, Can you pm me a link to buy a set please :)
leeparkes
Post Thu Jun 16, 2011 9:31 pm
These are the one's i bought but it looks like he's away now till 26 June :(
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT
Some more here though :)
http://cgi.ebay.co.uk/V8-Engine-Mount-R ... 518a0e28fa
Bristol_Jer
Post Thu Jun 16, 2011 9:37 pm
I bought a set of these as well, have got some uprated m20 mounts on the car at the moment, was going to do a back to back to test to see how they compare.
leeparkes
Post Mon Jul 11, 2011 8:42 pm
Pod times are in.
1st run was 14.3 then second was 14.2. I know i could of sqeezed a 14.1 out of it but the engine isnt running as it should so i gave up.
Crank sensor is giving iffy readings also its running quite rich. Injectors are a suspect too so with all those sorted hopefully it will be fine.
Word of warning, dont buy a crank sensor from GSF, picked one up saturday morning but before i put it on i tested it with a multimeter. It should read between 500 - 580 ohms to run right, GSF one read 730ohms 8O took it back with my multimeter at hand to swap for another but that was reading just as bad. got my refund and fooked off :-x
Anyway...
And another comical shakey video my lad took :chuckle:
You need the sound on, goo on dad thrash the mini.
lads eh!
[youtube][/youtube]
[youtube][/youtube]
Once its up to scratch ill be nipping over to Shakespeare's to do a few runs as its not that far from me. :cool:
realboss7669
Post Thu Jul 14, 2011 5:48 pm
Sorry I didnt get to hook up with you mate, we had a nightmare getting past the traffic for Silverstone F1. By the time we arrived at 12pm I think you may have gone. We only stayed an hour as the swarms of tiny flies were unbearable for my missus. Was great though! Your times look good. Be interested to see how your tweaks improve things. Are you considering fitting a turbo at any point? I would possibly, but only something modest ;-)
- E30 335 Cab (B3 3.3 Alpina Conversion)
- E46 330CI
- Beast 4x4 Van 5.9ltr
Post Fri Jul 15, 2011 8:10 pm
Give me a shout when you go to shakeys Lee, I might just have my track car ready for the road again :D
Bristol_Jer
Post Fri Jul 15, 2011 10:06 pm
Lee do you mean Shakespeare County raceway, Stratford upon Avon? Me and a couple of mates go there a few times a year, you going to a RWYB day?
leeparkes
Post Sat Jul 16, 2011 6:35 pm
James, i was there from about 8am till about 4pm :) havent really touched the car since the pod either,
well apart from monday i swapped the ECU for my old one with the pina chip in but it didnt make a blind bit of difference :(
Ive got a spare set of injectors to send off to be cleaned so thats next on my list, Im swaying towards a genuine CPS from BMW too but at around £80 a rip for something that may not cure it im a bit dubious about it.
Dan, ill let you know when im going, wouldnt be a bad idea for a 'meet'??
Where's Rav our tame meets organiser :D
Yes Jer its Stratford upon Avon 8)
http://www.shakespearecountyraceway.com/
leeparkes
Post Sat Jul 16, 2011 8:31 pm
realboss7669 wrote:Are you considering fitting a turbo at any point?
If i did go down the FI route im not sure id use an M30 to do it. :D
Post Sat Jul 16, 2011 10:27 pm
Why not, drop the turbo in and 450bhp easy :D
staley_turbo
Post Sun Jul 17, 2011 1:04 am
Turbo FTW!
leeparkes
Post Thu Jul 21, 2011 12:03 am
Turbo may be a future project.....
But, more to the point ive solved my running problem :woohoo:
Before it felt like somthing was holding it back and spluttery every now and then.
Changed/tested almost everything on the engine, i even tested the loom :mad:
It was the dizzy cap :?
I had a bit of a shed clear out the weekend and came across a nearly new genuine dizzy cap (came across about 5 of them,lol) but this one was in the best condition so gave it a quick clean up ready to put on.
Now, M30 bruvs, changing a dizzy cap on these donks is no easy feat, there's not enough room between the rad and cap to get it out, if there was say 5mm more room it would be a peice of cake.
But it wasnt..:banghead:
I ended up lifting the engine off its mounts about a couple inch with a trolley jack under the sump 8O
This gave enough room (just) to slide it out.
Anyhooo...
Once all back together i took it out for a blat. Nice country lanes are about 2 miles away from me so thats where i headed...
Lets just say its done the trick :) Fooookin hell! this is how a B10 should behave 8) it now pulls cleanly, smoothly and very strong all the way to the limiter, it doesnt seem to run out of breath like normal M30's do, @ 5k it keeps pulling hard. I suppose its the head work done by Alpina, cam, bigger valve's and Hemi chambers. I dont know??
All i know is i cant wait to drive to work tomorrow. :D
Well i dont know what was wrong with the dizzy that was on it, no sign of cracks and the contacts inside didnt seem that worn?
Ive seen some That look like the contacts have got an Afro on them :chuckle:
Here's the cap i took off
I dont know, maybe its failed inside??
Next up, Injectors, they have about 130k on them so well overdue a service.
If it isnt running perfect after that i may spunk out for a new CPS from BMW 8O
Oh, and i bewildered a Golf R32 driver tonight, so funny when he got to the next set of lights :chuckle:
Post Thu Jul 21, 2011 8:19 am
LOL, tell me about the change on the dizzy :mad: I did mine a while ago, but ended up taking the rad out instead.
Glad it's now properly running mate. :D
rob0r
Post Thu Jul 21, 2011 11:39 am
I'll check mine before the engine goes in!
leeparkes
Post Fri Jul 22, 2011 8:18 pm
Cant easily take the rad out of mine, i have to remove the front end to get to the bolts securing it, then the pita draining and bleeding the system again along with trying to get the bottom hose back on. :cry:
