Goosie's S50 Moredoor, 'Ring action
goosiegander
Zonegoose
Sat Apr 16, 2011 11:28 pm
Just a quick note,
Had a great drive earlier spanking it up the nearest stretch of dual carrageway, it was one of those moments where all the little niggling things i want to improve or fine tune were forgotten.
Happy days!
goosiegander
Zonegoose
Sun May 22, 2011 9:11 am
New doors and bonnet purchased from a nice chap called Peter yesterday, pictures to follow shortly :D
spook
League two here we come !!!
Sun May 22, 2011 10:26 am
Car looks great Chris
Alpina99
Sun May 22, 2011 10:30 am
A very nice looking car,
Very interesting to follow it's "evolution" !
Gone, but not forgotten !!
tomislav
Sun May 22, 2011 11:25 am
So how's the old girl doing?
goosiegander
Zonegoose
Sun May 22, 2011 7:49 pm
Thanks Guys,
Good to meet you yesterday dude!
Yes the turd has seen a fair amount of action over the last few years, as it stands i'm looking into a cometic MLS head gasket to loose .5mm to increase compression ratio and produce more power n/a, will be taking advice from Ant on this. My thinking is that rather than going for the perminancy of decking the block the unit can go low compression again without drama. Thinking of selling the engine if the right money is offered and buying the building blocks of a 3.1 litre m20 from IE.
No real issues with the car beyond needing to replace a wing at some point in the future.
Yesterday, as mentioned above, i popped over to Peter's and relieved him of 4 doors and a bonnet. While the car looks ok in pictures the doors (and Bonnet to an extent) were like the surface of the moon with all manner of small dings and tin worm was starting to set in on the leading lower edges.
So with some spannering...
Much nicer pannels to be corrected prior to the BBB BBQ next friday.
Set about curing a bad case of red/black door socket corrosion to get the central/dead-locking operational. LM & Copper Grease applied to ensure nice smooth action all round.
Even some waxoil, seemed rude not to with the cards off...
A bit of effort but very pleasing to have some straight pannels back on the car
Thu May 26, 2011 11:10 pm
:cool: :cool:
goosiegander
Zonegoose
Tue Jun 14, 2011 8:02 pm
Well today a colleague backed into my car whilst it was parked
The result? every panel on the front end bent, plus the drivers lights smashed...
But being council and all a 'drift-spec' repair has been made...
Driftcock FTW,
Gutting but these things happen and at least it looked shiny the other week...
Updates to follow, even if its pictures of the turd being weighed
adamski80
Tue Jun 14, 2011 8:09 pm
Not good, Few choice words exchanged or not?
goosiegander
Zonegoose
Tue Jun 14, 2011 8:13 pm
It was an honest mistake so i'm fairly zen about it,
Insurance won't be much of an issue, just damned inconvenient :(
Tue Jun 14, 2011 9:02 pm
Bummer! If through insurance insist on OEM panels!
penton08
Tue Jun 14, 2011 9:20 pm
FFS :cry: How long has that bonnet been fitted? A month? I have seen less damage result in a cat status, it should not come to that but i will get your valuation sorted for you mate.
goosiegander
Zonegoose
Tue Jun 14, 2011 10:10 pm
Cheers Dude,
Trying to work out if its clipped the rad as an unhealthy trail of fluid just followed the car from the house to the garage, if so i'll just throw 10 litres in the boot spare in case...
I'm sure you have spare rads kicking about...
Dan320is
Tue Jun 14, 2011 10:14 pm
What a kick in the testes!
goosiegander
Zonegoose
Tue Jun 14, 2011 10:15 pm
bss325i wrote:Bummer! If through insurance insist on OEM panels!
Most definatly Barry,
Thats two insurance cases in as many months almost!
Neither my fault i hasten to add...
First repair estimate was £1400 i'm guessing this one (assuming properly corrected) at £2000,
thats a good 325 right there... Its crazy! 8O
d6dph
We always miss each other at bbb don't we Goose, Nathan said earlier that you are going tomorrow :(
Shitty luck with the car, Hope you get the right outcome. It's a top car.
Tue Jun 14, 2011 10:16 pm
FFS :(
goosiegander
Zonegoose
Tue Jun 14, 2011 10:23 pm
Jhonno wrote:FFS :(
Look on the bright side Dan, maybe i'll buy that peach of a compact you are looking to offload winkeye
Thanks Dave! -If you can make it to the next BBQ it'd be good to catch up, That goes for you too Dan! (is) And Jhonno as well! :D
d6dph
Tue Jun 14, 2011 10:24 pm
I'm there mate, I've been given orders 8)
goosiegander
Zonegoose
Tue Jun 14, 2011 10:28 pm
Well bring the camera, if only to get 'arse end' shots!
winkeye
Tue Jun 14, 2011 10:47 pm
goosiegander wrote:Well bring the camera, if only to get 'arse end' shots!
winkeye
Perv!!
Tue Jun 14, 2011 10:48 pm
You're welcome to come buy the Compact though :wink: :P
goosiegander
Zonegoose
Tue Jun 14, 2011 10:50 pm
bit of 'pact action? just as deviant! :D
Tue Jun 14, 2011 10:55 pm
Definitely.. It is like an e30 to drive though! With better steering and brakes..
goosiegander
Zonegoose
Thu Oct 06, 2011 6:49 pm
Well as of late not a lot has happened as i'm 'barging' it day to day, the moordoor has only been out of the garage once since the touring rocked up,
Pressed up the tyres and gave it a run, i guess i've been spoiled because it feels so up and together after driving a car with standard suspension and comfort seats,
Need to replace the rack and probably throw on a new clutch kit,
Worth fitting a lightened flywheel at the same time?
Thu Oct 06, 2011 6:54 pm
Yes! A lightened fly is a must!
Thu Oct 06, 2011 7:04 pm
Lightened flywheel for sure! Will liven it up even more..
goosiegander
Zonegoose
Thu Oct 06, 2011 7:13 pm
Another call to BBB then, :D
anyone in particular we know of selling B8 front dampers? (thinking of the m3)
Thu Oct 06, 2011 7:46 pm
Not sure after ECP's loss of supply..
goosiegander
Zonegoose
Sat Nov 12, 2011 4:53 pm
Last week i collected some freshened 15" BBS alloys,
Standard and Nogaro silver,
Will probably be a good few weeks before they are mounted as i'll be moving house very shortly, that and i still need ferry some parts up from BBB,
Aside from that, half a tank of Vpower and 6 months rent, oh and shes due an oil change...
tomislav
Sat Nov 12, 2011 5:49 pm
Get it done, you know its not hard. And especially with your 2.8, you wanna be looking after that toy of yours!!!
Have you ever had this 2.8 dyno'd? Or have i just not bothered reading the thread? Lol
goosiegander
Zonegoose
Sat Nov 12, 2011 6:21 pm
Thanks Dude,
The link to the mapping and Dyno charts is at the top of the 1st post in this thread,
Sat Nov 12, 2011 6:24 pm
Nice rimz bruv.. :)
Dezzy
CR24v it's a lifestyle
Sat Nov 12, 2011 7:05 pm
Don't they look nice! :cool:
goosiegander
Zonegoose
Sat Nov 12, 2011 7:39 pm
Cheers Dan and Dez,
I've spent a few evenings now coating them with poorboys sealant, seems nice enough to work with although getting into every little recess of the spokes is a fooking pain, two of the center caps have had three coatings and one of the alloys has had a single good coat.
I think i'll try for two good coats on the wheels before the tyres are mounted and a third after, i havent touched the inner barrels as these will need balancing weights.
Toyo Proxes again, never had any issues and i'm yet to be recommended a better alternative in 205/55/15.
Still need to sort bonnet, valance, wings... rear arches could do with a tidy as well. At least in its new home these issues can be tackled with a cup of tea in hand and banging choons to spur me on,
Have to send her to Penton for a replacement rack soon, manual steering is a pain in the arse!
