Rear subframe bush replacement.
pimpmobil
Fri Jun 03, 2011 9:37 pm
Just finised replacing my bushes. Not that hard. YOU WILL NEED SOME SORT OF EXTRACTION TOOL.
Place the new bushes in a bag & then the freezer the night before starting work.
First drive up onto car ramps.( Rear end :-) ) Block front wheels.
Place trolly jack under the middle of the subframe to take the weight & loosen the 2 coller nuts ( 1 each side )about 6 turns, do not remove. To remove the 2 Knurled bolts ( 1 each side ) you will have to use a large hammer ( well i did ) untill thay move. Then remove the nuts & the bolts. Remove the 4 push rod bolts & pushrods. Let down the trolly jack so that the subframe just hits your exhaust. Now it should be posible to place the extraction tool in place to remove the bush. You may have to help pull down the subframe.
If like mine the ally rod has snaped inside the car bodywork you will have to drill 1 side of the ally bush & the using a chisel remove the rest of the bush ( BIG THANK'S TO DAVE T ). Coat the new bushes in car wax & fit to subframe. Lift subframe & fit Knurled bolt, push rods & nuts. Hope that helps. Any questions just ask.
MartinSE
Sun Jun 05, 2011 7:38 am
Well done! What sort of extraction tool are you referring to?
pimpmobil
Mon Jun 06, 2011 10:39 pm
Hi Martin
If you go to this link you can see what i used.
But i did make mine.
Hope this helps.
schnaarf
Mon Jun 06, 2011 10:51 pm
starting to persuade me to tackle mine. Do you have a picture of your tool??
Mon Jun 06, 2011 10:55 pm
schnaarf wrote:starting to persuade me to tackle mine. Do you have a picture of your tool??
:D :D :D
schnaarf
Mon Jun 06, 2011 10:56 pm
damn.
sanitroc1
Tue Jun 07, 2011 7:38 am
Have a look for the thread " diy rear beam bush puller " . There are two versions both made out of scrap that was lying around and both work .
**BANNED**
Tue Jun 07, 2011 8:04 am
Youth is wasted on the young.
E30-830
Tue Jun 07, 2011 1:20 pm
Hey, not trying to hijack the thread but seeing as you are talking about the rear subframe.
I tried to tackle this about a year ago but the Allen Key bolts that hold on the Subframe are all completely rung, the previous owner must have tried to do them before. :(
Any way to work around this? :)
schnaarf
Tue Jun 07, 2011 1:51 pm
E30-830 wrote:Hey, not trying to hijack the thread but seeing as you are talking about the rear subframe.
you could try smacking in a torx tool. Works for the allen bolts on the disk rotors!
PG325
Tue Jun 07, 2011 2:16 pm
Drill them out and replace with new nuts and bolts, it's what most people have done.
**BANNED**
Tue Jun 07, 2011 4:41 pm
Slice the captive nut off the back of the mounting plate with Mr Angle Grinder.
Use standard M8 bolts of a suitable length with nyloc nuts going back.
Take great care not to damage the lower plate,I think that they are currently on back order!
Tue Jun 07, 2011 4:59 pm
I have a pair for sale at present if you damage them :wink:
E30-830
Sat Jun 11, 2011 11:15 am
Thanks guys, :) so theres lots of ways around it den. :P I'll try drilling and replacing with nuts and bolts. :)
Is it really necessary to chop the captive nut off, i mean would it be safe to leave them and just drill and replace?
**BANNED**
Sat Jun 11, 2011 12:16 pm
E30-830 wrote:Thanks guys, :) so theres lots of ways around it den. :P I'll try drilling and replacing with nuts and bolts. :)
Easier and quicker to slice the nuts off!
(as the actress said to the bishop)
I replace with stainless steel bolts/nyloc nuts,I've need to take them of once,so I'll need to take them off again sometime in the future,this way it will be easy next time.
pimpmobil
Sun Jun 12, 2011 2:30 pm
Hi
Sorry to not have answerd you emails but have not been on pc for a long time. Sorry no pics of the tool but same as To remove bolts i just sprayed with WD40 the day before & used a larg mallet. You may be able to use a bottle jack on the bolt & push it through. You never know it may work, hope it will.
