crank position sensor
Mops
Post Thu Oct 27, 2005 12:19 am
Hello.
I have an early (1985) 325i, and I'm installing megasquirt there, but I stuck at ignition pickup.
Now, I dont have the tooth wheel at the front of the engine, instead there are two VR cencors on the back of the engine, of which I know one reads flywheel teeth's and the other reads some flywheel mark for the ignition system.
I would like to know (without removing the gearbox from the car) the exact configuratino of these, namely
1. how many teeth on the flywheel, are there some purposely missing ?
2. the oher sensor that reads the mark... is there only 1 mark or more (might be 3 to read 3 tdc's), and in what location relating to TDC ?
That info would be greatly appreciated..
Thanks in advance,
Mops.
Turbo-Brown
Boost Junkie
Post Thu Oct 27, 2005 8:09 am
There are just two plips on the flywheel if memory serves!
TBH, you might be better off buying a trigger wheel and sensor bracket from a later engine. Mine's a 1985 car and I had the same problem but the holes for the bracket are drilled in the front of the block so it's a simple case of removing the old front pulley and bolting on the new one and sensor bracket :)
Mops
Post Thu Oct 27, 2005 7:44 pm
Thanks for info.
Yeah, i'm trying to source out the front toothed pulley, BUT i cant find one for reasonable price around here. I found 1, but they want me to buy whole bottom end of 320 engine... for too much money.
Ant
Retired Team Member
Retired Team Member
Post Thu Oct 27, 2005 8:15 pm
Try Jon B for the sensor + bracket/wheel and pulleys.
He'll almost defo have a few on the shelf(follr ? :lol:)
Mops
Post Thu Oct 27, 2005 8:22 pm
shipping from UK to new zealand would be cost prohibitive, but thatnks anyway !
Ant
Retired Team Member
Retired Team Member
Post Thu Oct 27, 2005 8:33 pm
I sent a complete head to the Us , 2 days express service insured was Ԛ£93
thats 15K and comparable distance, you're looking ' 2 kgs max for those... slower service,say 5 days ish, I'd not discount it yet dude
cheaper than a complete bottom end though for defo
Mops
Post Thu Oct 27, 2005 9:04 pm
you mean you sent a complete head to US ?
how many kg's was that ?
remember that NZ is on the opposite side of the globe :) some ppl say it's the end of the world....
