318is discs ..Help needed
red50x
Fri May 20, 2011 3:00 pm
i just noticed my 1990 318is discs are badly scored and need to be replaced .Are these the same as regular 318i discs or do they take a different disc ??
Also, are they difficult to replace .. ? is there a link with instructions ? .. much appreciated ..tks
chips
Was Pzero
Was Pzero
Fri May 20, 2011 3:12 pm
They should be the same as 325i discs.
They are very easy to replace. But if they disc is scored you should probably be replacing the pads at the same time.
Cypriotgeeza
Tue May 24, 2011 8:39 am
Anytime you change discs you should replace the pads!
Easy job to do mate..
Check my M30 build threads:
chips
Was Pzero
Was Pzero
Tue May 24, 2011 8:40 am
Cypriotgeeza wrote:Anytime you change discs you should replace the pads!
/\ that
Tue May 24, 2011 9:12 am
Contact our Eurocarparts man, Meatballs82, for a price on Pagid discs and pads.
