i just noticed my 1990 318is discs are badly scored and need to be replaced .Are these the same as regular 318i discs or do they take a different disc ??
Also, are they difficult to replace .. ? is there a link with instructions ? .. much appreciated ..tks
318is discs ..Help needed
They should be the same as 325i discs.
They are very easy to replace. But if they disc is scored you should probably be replacing the pads at the same time.
- Cypriotgeeza
Anytime you change discs you should replace the pads!
Easy job to do mate..
Check my M30 build threads:
/\ thatCypriotgeeza wrote:Anytime you change discs you should replace the pads!
- Brianmoooore
Contact our Eurocarparts man, Meatballs82, for a price on Pagid discs and pads.
