wondering why it is that on the smiley headlights
some of them when you put the sidelights on the elipsoid lights up dim with the sidelight bulb too
and on others (mine) when you put the sidelights on its just the sidelight bulb that lights up.
is it a common difference or does mine have a fault?
any suggestions
headlight differences
tylerma
This was dim dip function on face lift cars up to around autumn 88.
Switched in two large resistors, which live right at the very front of the left hand inner wing.
They connect into the body loom part way back the left inner wing by two round black two pin plugs and sockets.
tylerma
thanks for the speedy reply BrianBrianmoooore wrote:This was dim dip function on face lift cars up to around autumn 88.
so could they be unplugged and then it would be just the sidelight bulbs that would light up
or is it not as simple as that
Aha!
so how do we go about removing the elipsoid dim function from the sides?
Yes, just pull the plugs.
tylerma
Brian you are a star
if i ever meet you
got a pint with your name on
if i ever meet you
If I ever get to call in all the pints I've been promised, I'm going to have one hell of a piss up.
tylerma
lolBrianmoooore wrote:If I ever get to call in all the pints I've been promised, I'm going to have one hell of a piss up.
mrLEE30
see i told ya!!!! woohoo i was right!! soon will be on brianmoooores level!!DanThe Posted: Wed Oct 26, 2005 1:34 am Post subject:
Aha!
now dan soon you can have these!!!
Great stuff guys,
simple and effective!
