Definative answer.
Both switches at the front are standard on a four door with rear electric windows.
Rear doors have their own switches as well as the ones on the consule.
Front right "switch" is a resettable fuse. It will pop out and cut the power to all the windows if any of them jam, or the button is held down too long. In normal use, pushing it should not do anything, except maybe stop the windows while you push it.
Front left switch is a switch which disables the windoew switches on the rear door cards, but leaves the rear switches on the console working.
hi mate, is that car ever parked on a cobbled road that runs parralel to princes st in edinburgh? cant think of the name right now. if not then theres one very simmilar
