Borg Warner Turbocharger deal £530 + shipping
Traders Section
Gunni
Post Thu Mar 17, 2011 12:23 pm
I´m offering a turbocharger that will fit most peoples turbocharging needs.
On a M20B25 this turbo came on full boost at about 3700-3900rpm (1.2bar boost) in most gears. It starts boosting very early on and provides excellent spool characteristics.
On a M50B25 is showed 0,2bar boost @ 1900rpm, 0,5bar @ 2600rpm in 3rd and above gears.
On a M50B28 it comes on full boost of 1bar at about 3500rpm.
Leaving you with half the rev range for a very wide torque curve
In both cases it´s making boost from early 2000rpm onwards
If used with a split pulse turbo manifold it will provide the best possible spool characteristics.
The inducer is 57mm on the compressor
The exducer is 65mm on the turbine
The compressor wheel has Borg Warners extended tip technology.
It has split pulse turbine housing
It has map width enhancement compressor cover
It is a non wastegated housing
I´d reccomend this turbocharger for M20/M30 and M50´s alike for anything between 300-500hp.
There is a 6week waiting period on the turbo from ordering, and what is why I can offer it at this reduced price.
This price is WITH VAT.
This is a 100% actual authenticated Borg Warner K27-7 Turbocharger
Some pics of installed turbo
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
Ali786
Post Fri Apr 01, 2011 7:55 pm
how much for this
Blue 1988 320i convertible
Gunni
Post Sat Apr 02, 2011 10:10 am
It says 530quid in the title.
that´s with VAT btw.
Gunni
E30_Crazy
Post Sat Apr 02, 2011 2:31 pm
Gunni, I have heard of you being revered in the E30 FI scene. Do you have any kinda of ballpark figure on what to expect from an M20B25 with this setup? Or maybe a B27/B28 M20 build?
Gunni
Post Sun Apr 03, 2011 1:06 am
It all depends on how hard you push the engine , if it has a forged bottom end or what.
Expect this turbo to be able to see you to 550hp depending on your engine setup,
A 2.7 or a 2.8 will not able to extract more power from this turbo but would come in earlier then on a 2.5
I´d use this turbo for anything between 320-550hp.
Gunni
Gunni
Post Thu Jun 16, 2011 11:49 pm
So I´m about to order a few of these turbos.
Anybody want in right now?
Gunni
deepan
Post Thu Sep 22, 2011 5:36 pm
are these still available? whats the best price on them?
Gunni
Post Thu Sep 22, 2011 7:27 pm
Same price and yes available.
Gunni
ross2009
Post Sat Oct 13, 2012 8:16 pm
gunni i will be putting in a order for one of these in the new year as my turbo has just shit its self do you think youll have them in stock then or will there still be a 6 week waiting list ?
Turbo M20
v8 project 6.0 twin turbo
craigieeb
Post Sat Oct 13, 2012 8:21 pm
Dont think he has any of these left Ross mate,
Think he can get one of the ones i'v got tho
winkeye
I think it's near enough the same turbo, but with different housings
ross2009
Post Sat Oct 13, 2012 8:23 pm
the spec on yours pretty much the same then ?
Turbo M20
craigieeb
Post Sat Oct 13, 2012 8:29 pm
That A/R is a 1.22, while the new one is a 0.83 housing
Making it spool up a bit quicker
ross2009
Post Sat Oct 13, 2012 8:31 pm
when does yours start to spool ?
Turbo M20
craigieeb
Post Sat Oct 13, 2012 8:42 pm
at the moment,
about erm..... I think around 3000 rpm?
mebbies sooner
I havnt driven it yet so cant say im 100% on that one
I'll know next weekend tho
(fingers crossed)
ross2009
Post Sat Oct 13, 2012 8:44 pm
hmmm mine made positive boost at around 2200 which is what i want again really
Turbo M20
craigieeb
Post Sat Oct 13, 2012 10:45 pm
Like I say, I cant be 100% sure, it's only been on the rollers
it came off there, straight on the trailer, then on to the drive,
I had a little cheeky shot, while taking it off, but wasnt taking any notice of, anything really lol
I'v got to change the rear beam & trailing arms
It should be done by next weekend,
so I can tell you then what it's like fella
But chances are, you'll have a turbo sorted by then
momomo
Post Fri Jan 10, 2014 2:34 am
Lad a tubo go on any e30 engine and whats spoon? Is that when the tubo kicks in? :o
momomo
momomo
Post Fri Jan 10, 2014 3:12 am
Should say LADS!
momomo
Should say LADS!
craigieeb
Post Fri Jan 10, 2014 9:02 am
momomo wrote:whats spoon?
It's what you eat your soup with..
ross2009
Post Fri Jan 10, 2014 9:16 am
lmao
Turbo M20
Andyboy
Alpina Colada
Post Thu Oct 15, 2015 2:22 am
Or a shit E39 wheel!
