my 325i cab wont start
jonnyboy
Thu Mar 31, 2011 11:32 pm
hi, ive got a 1989 325i m20 i went to the shop on my dinner beak, it run a little lumpy for the first 10 sec then was ok but when i went to drive home from work it wouldnt start.
ive had a look and ive got no sparks can anyone help me on what to look for and how to test it. cheers :? andy
Thu Mar 31, 2011 11:35 pm
Does it have an immobiliser fitted?
jonnyboy
Fri Apr 01, 2011 1:40 am
Rav335uk wrote:Does it have an immobiliser fitted?
no am sure its as not got one. it turns over but there no spark at all. :?
GovR
Fri Apr 01, 2011 2:03 am
I had the same problem (yes I know its not the same car but could be similar?) on a peugeot 306 - turned out to be a cracked and rusty Fuel pump relay/module = no fuel no spark.
Check your fuel pump relay + crank angle sensor.
jonnyboy
Sat Apr 02, 2011 1:32 am
does anyone knw where the fuel relay is and i will order a new crank sensor tomo. unless theres a way of testing it.cheers
Barx325i
Sat Apr 02, 2011 2:30 am
Earth strap/battery neg etc, have you been giving it some pain with the recent weather?
jonnyboy
Sat Apr 02, 2011 9:12 am
Barx325i wrote:Earth strap/battery neg etc, have you been giving it some pain with the recent weather?
no its been fine all over winter.
jonnyboy
Sat Apr 02, 2011 6:06 pm
iv tried all of the above and still nothin but please please help !!
jonnyboy
Sat Apr 02, 2011 8:16 pm
HI, ive changed everything i can thnik of. am now thinking it could be a bad earth could anyone tell me where all the earths are. plzs its getting dark.
Gristo
Sat Apr 02, 2011 8:57 pm
you might have problem with ECU..my 327 has similar problem, and the problem is somewhere in ECU, sometimes it's working,sometimes it's not... I had to push the main plug of ECU really hard to its socket..after that it was working for a while.. then I swaped the ECU from my friends 325 and had no problems after that.
jonnyboy
Sun Apr 03, 2011 1:47 pm
Gristo wrote:you might have problem with ECU..my 327 has similar problem, and the problem is somewhere in ECU, sometimes it's working,sometimes it's not... I had to push the main plug of ECU really hard to its socket..after that it was working for a while.. then I swaped the ECU from my friends 325 and had no problems after that.
ive swap the ecu and sill note there. :cry:
jonnyboy
Sun Apr 03, 2011 2:38 pm
willnz wrote:Just to make sure, when you crank the motor, the fuel pump runs? Yes/no??
(assuming it does) Check the coil primary and secondary resistances.
Check primary resistance between terminals 1 and 15, (disconnect the wiring from the coil), you should get 0.5 ohms.
no its just reading 1
Check secondary resistance between terminal 15 and the king post (centre), you should get 5000 ohms.
its reads about 1053 ohms
Or swap it for a known good coil and try.
ive tryed a new one its sill the same.
Check that your rotor arm is intact. Measure the resistance between the centre and outer contacts, you should read 1000 +/- 20% ohms.
Check the distributor cap for cracks and that the centre carbon brush is ok and spring is working. Measure the resistance from the outer centre post to the carbon brush, you should get ) ohms.
Check the resistance of the HT lead from the coil, you should read around 2000 ohms cap to cap.
cheers for your help ive got fuel and resistance between terminals 1 and 15 is just readin 1 and secondary resistance between terminal 15 and the king post only reads 1053 and coil ht lead to cap reads 1 . :(
[/list]
jonnyboy
Sun Apr 03, 2011 2:57 pm
am well lost now some said about it could be the obc causing it am really stuck.
jonnyboy
Wed Apr 06, 2011 12:58 am
as anyone got any idea why i have really poor ohms coming to and from my coil? am running out of ideas :?
srmalek
Tue Apr 12, 2011 3:38 pm
Sorry to hijack the topic, but can I test this method for my 323i e30 with m20 engine year 1985
srmalek
Tue Apr 12, 2011 3:39 pm
Ops my question went into the quote box,
m0gsia
Fri Apr 15, 2011 2:43 pm
Some multimeters will read 1 on the resistance measurment when the reading is out of bounds.
Is it reading 1 when the probes aren't touching anything? Does it read 0 when the probes are touching each other?
Taz
Fri Apr 15, 2011 2:52 pm
OBC controle module box check it if your car has a obc
mr_dink
Fri Apr 15, 2011 3:38 pm
If you mulimeter is saying -1 on the display this normally indicates an open circuit, i.e your coil may be faulty.
