fuel pump
popey7676
i have an external fuel pump on my 87 pre face chromie, is that the only fuel pump? or is there another in the tank?
staley_turbo
Thats the only one.
Jim320i
- E30 Zone News / COTM Team
No, there will be another in the tank behind the driver seat... There is in my 320i, and I know of 3 other 6 cylinder chromies.
staley_turbo
You sure jim? on mine there is only pick up and level in the tank?
Jim320i
Hmmm... I thought I was sure, but I may be confusing what I thought to be a pump with some thing else? I have wired it up to a battery before now though and its pumped the fuel up so assuming its a pump?
Anyone else elaborate?
highlander112001
i have a 320i chromie
and only have the one pump located underneath on the passenger side
There appears to be versions with both set ups, but I've no idea what models/ages have which, as I don't get involved with pre facelift stuff.
The only E30 I have with an external pump is a facelift '87 318i, and that has two pumps.
popey7676
looks like i might need to have a good look at the tank! thanks for your help peeps!
m8782538
Propably a low pressure sender unit in the tank, then the external fuel pump.
All the tank assemblies have a three pin level sensor. Ones with a pump have a two pin plug as well.
