DAD doing that'retro look' taken by my young daughter
MANNO
Post Fri Mar 11, 2011 12:42 am
delete
MANNO
Post Fri Mar 11, 2011 12:44 am
deleted
MANNO
Post Fri Mar 11, 2011 12:49 am
By the way - if youd seen my earlier thread on my oil starvation issue - the car was sounding like a buggered 1960s VW at the top end - very rattly lifters BUT at only high revs - motorway only 70 mph and NOT at start up or city driving just when hot and hi Revs High pressure ...
SOLVED it !! we lifted the engine from below and dropped the sump and all was revealed
It was a combination of a buggered split Sump gasket - letting air into the sump and also a stray loose bolt in the sump half blocking 50% of the oil pickup inlet mesh for the oil - so drop in oil pressure at high revs on motorway - there was no varnish or sludge evident in the sump or pickup ....which was a relief
she drives like a baby now - smooth and effortless in auto - im one very happy owner - proving a bit of tenacity and enquiry can solve tappet clatter - she runs so quiet now
also going to use this wonder stuff from states with no detergents AUTO RX
http://www.auto-rx.com/index.html
sounds very very good - and its not a harmful flush
also bought the Zinc Phospherate additive - heard very goo things from the states and UK and Germany as you / we all know since 93 when CATS came in ... even our good oils have dropped the valuable Zinc content levels needed in our engines -
again this is not a harmful additive and comes with excellent reviews - google it etc
maybe get that zinc and phosphorus back in your Oil via this ;
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 959wt_1141
beemerbird
Post Fri Mar 11, 2011 9:53 am
Flo and Dad's day out, and you took her to a carpark :mad: :D
MANNO
Post Fri Mar 11, 2011 7:32 pm
your from Essex I'll let you off :wink:
