If you're going to be sticking the gas on mate then I'd speak with someone like Wizards of Noz for any specific advice.
Double check on my recommendation mate, I know it is the BKR6's that are the recommended heat range, but the letters that follow the 6 dictate the type/ material.
I think you can get BKR6E
BKR6ES
BKR6EP
It may actually be the ES you need as I think the EP is a platinum tip, which may not be needed. I think platinum tip plugs generally are used in cars with long service intervals/ where the plugs are an utter cooont to change.
Bottom line, listen to Dan not me when it comes to anything
