M52 plugs
craigieeb
Post Tue Feb 15, 2011 6:50 pm
Wat are the best spark plugs for the M52?
I was thinking of the Iridium plugs(Denso/NGK) but they are a bit pricey
so what do people suggest??
Post Tue Feb 15, 2011 6:56 pm
I just use the standard plugs, bosch, beru, ngk etc etc, they all seem to be as good as the other. Very common plug this one, used on lots of other manufacturers engines which is why they are only about £2-£3 per plug
NGK BKR6 EP mate
craigieeb
Post Tue Feb 15, 2011 7:00 pm
Ok, I'll give thone NGK's a try Lee/Dan
I was looking for a plug to give me that little bit extra,
as i'll be running the direct port nitrous on the 2.8
but I'll see how the NGK BKR6 EP's cope
8)
Post Tue Feb 15, 2011 7:11 pm
If you're going to be sticking the gas on mate then I'd speak with someone like Wizards of Noz for any specific advice.
Double check on my recommendation mate, I know it is the BKR6's that are the recommended heat range, but the letters that follow the 6 dictate the type/ material.
I think you can get BKR6E
BKR6ES
BKR6EP
It may actually be the ES you need as I think the EP is a platinum tip, which may not be needed. I think platinum tip plugs generally are used in cars with long service intervals/ where the plugs are an utter cooont to change.
Bottom line, listen to Dan not me when it comes to anything :)
craigieeb
Post Tue Feb 15, 2011 7:19 pm
:lol:
Dont talk yourself down Lee man
what you said there made sense
some of it was utter sh!te like lol
naa it's all good info lee, i was using the denso ones on the 2.7 i just thought id use the same on the M52
infact these ones
http://cgi.ebay.co.uk/6-x-DENSO-HKS-IRI ... 2051wt_753
unless anyone else has used better
