S50 sump baffles
vanos
Just a quicky, is it wise to fit a baffle plate to the M50 E34 sump going on to my S50 motor.
The E30 going to be a road car with occasional track days, so is having baffles important.
ajay
imo definatly even if its a road car,my s50 lasted 2weeks on the road let alone track,before it started knocking.Once stripped down some of the shell showed strong evidence of possible oil starvation.just launching it from the lights(not that i condone this manner of driving) can cause oil starvation to the pick up.Other friends who have suffered similar engine failure would not consider spending all that cash and effort to miss out a such a crucial part. Its a pain i know but do yourself a favor,don,t be a fool like i was. Others may have other opinions but just sharing my experience,good luck fella
ultralinear
I killed my MR2 by drifting round roundabouts. The big end went big time!
vanos
Thanks guys, sounds more critical to have one than I thought first off.
I found a place on a google search in the USA that sell them, is there any places in the UK that sell them
ultralinear
I'd like them for my M50 if possible too... Ideally dry sump would be nice!
ian332isport
No Baffles in my sump. It's been to the Ring, Brands, Bruntingthorpe, Curborough and the Pod, and never had any issues.
I'm not saying they won't help at all, but not fitting them does not mean impending doom and an empty wallet. S50's are known to spin the odd shell even with the proper S50 sump fitted, so don't necessarily assume that any failure was down to oil surge. This is generally due to stretched big end bolts which can be stopped with some ARP (or similar) rod bolts.
Ian.
Ian.
vanos
I was going to do the shells and ARP bolts anyway. Is it wise Ian to change the oil pump for a new BMW pump
ian332isport
I would (and did) personally.vanos wrote:Is it wise Ian to change the oil pump for a new BMW pump
Mikey_Boy
Any baffles will help you - get in touch with Nigel aka alloyproducts on here and he might be able to help you. He does an exchange kit for M20s - not sure about S50s but worth a PM to him.
Cheers,
Mike
Cheers,
Mike
e21Jason
the one VAC sell in the USA is damm simple bit of folded alloy with a hole in it
Jason
Jason
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
Dave_M3
And apparently that one doesn't even fit perfectly after giving mad money for it!!!e21Jason wrote:the one VAC sell in the USA is damm simple bit of folded alloy with a hole in it
Jason
furbster
I'm also after a baffled sump for mine, I've done Oulton Park (Track and Drift) and Brands with no issues but I'm off to Spa in April and desperately want it done by then. ARP Bolts are a definate too.
If I get any joy in finding someone I'll post on here, I know Johnno is going to need one done soon too.
THIS MIGHT BE A STUPID QUESTION BUT is it the standard S50 sump that stays with these conversions or is the sump off a different engine?
crossie
if your is an S50 in an E30 and no sub frame mods then a different sump
E39 525 - I think is the sump of choice
glenn
- Engine Transplant Services
e34 m50crossie wrote:if your is an S50 in an E30 and no sub frame mods then a different sump
E34 M50 sump, or E38 728i
I believe Jhonno already has his sump baffled
vanos
There is a E39 523i in the local breakers, I was thinking about the sump but it looked different so I steered clear, will it fit a S50 motor or not ?
It will fit the engine, but not around an E30 crossmember
Read the thread in M50 conversions, there is a list of most compatible parts
furbster
Thanks, I bought the engine off jim330ci on here but havent been able to get hold of him to ask the question.DanThe wrote:E34 M50 sump, or E38 728i
Jhonno's sump is baffled but he needs another one done for
His latest build I believe.
furbster
Anyone tried these http://store.vacmotorsports.com/vac---e ... p2136.aspx
Dave_M3
Apparently they don't even fit that well and for what they are (abit of formed alloy) are way over-priced once you have them landed over here with shipping and duty.
furbster
I desperately need mine done before spa next month and don't seem to be getting anywhere fast.
Turk fitted one I think, check his thread
furbster
I just checked, he fitted the VAC motorsport one.DanThe wrote:Turk fitted one I think, check his thread
vanos
Those VAC ones seem like a small amount of cheap alloy for a lot of money and postage, might be worth asking somebody who races BMWs to have a look.furbster wrote:I just checked, he fitted the VAC motorsport one.DanThe wrote:Turk fitted one I think, check his thread
Would Muinch Legends be the sort of place to ask
e21Jason
Munich Legends are more like to run the bank with their punters money
Dan could probably get one made or some like E T A motorsport who prepare a lot of BMW's at club racing level.
Jason
Jason
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
furbster
Thanks guys. I'll try ETA Motorsport today. Ill google them for a contact no.
Dave_M3
Shame I'm using the 3.2 sump with the S54 otherwise I'd be happy to make one up or make drawings for people :p
Might stick an M52 I have in the garage into the Touring now though rather than the M42 thats almost ready so will look into making a baffle while I have the sump off.
Dan or ETA would probably be the best people to go to at the moment though for getting something made up.
I will have a look into it if I get chance, wont be anytime soon though
furbster
Thanks guys, just as an update I have tried ETA Motorsport, Bexley Motor Works, Brise Fabrications and HT Racing. None of which could help. I have just mailed turner Motorsport in the states to check fitment of one of their kits also.
crossie
could always copy it if you buy one!furbster wrote:Thanks guys, just as an update I have tried ETA Motorsport, Bexley Motor Works, Brise Fabrications and HT Racing. None of which could help. I have just mailed turner Motorsport in the states to check fitment of one of their kits also.
I would be interested if you do!
I was under the impression they didnt fit very well?
furbster
I thought that was the VAC Motorsport jobbies?DanThe wrote:I was under the impression they didnt fit very well?
I need to do something fairly sharpish as I don't want to do Spa without a baffled sump!!
furbster
Just had this reply from Turner Motorsport, what do you guys reckon?
Shane,
Baffle kit will not fit. I did the same conversion in an E30 M3, 3.2 using a E34 525 pan.
You really do not need a baffle in this engine unless you plan to run on racetracks that have very steep banking, like, Nascar banking. These engines simply do not suffer from oil starvation unless they are under a very heavy g-load on a steep banked oval track.
-Doug
Douglas Mahar
Turner Motorsport
Shane,
-Doug
Douglas Mahar
Turner Motorsport
Do you have an oil pressure gauge fitted? For me, that would be more of a priority at the moment
furbster
Yes, but it's hard to keep an eye on the gauge when cornering at 120mph round Poulton.
