heated washer jets
gazza
Post Thu Oct 13, 2005 3:32 pm
how do they work ....do they heat up when the washers are operated or do the run hot all the time. (i had some on a car before and they came on when the heated rear screen/mirrors were operated) i have a cab so no heated screen or heated mirrors ....cheers
Templ8e30
Post Thu Oct 13, 2005 3:46 pm
Hi Gazza, the heated jets have power all the time the ignition is on. The jets have a thermistor inside them that stops them from heating when not needed and prevents them from burning out. I think they start to work at about 5 celcius.
They don't get warm enough for you to feel the heat but they do work very well.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Demlotcrew
Post Thu Oct 13, 2005 7:51 pm
Templ8e30 wrote:Hi Gazza, the heated jets have power all the time the ignition is on. The jets have a thermistor inside them that stops them from heating when not needed and prevents them from burning out. I think they start to work at about 5 celcius.
Cheers,
Iain T
Are you sure?
Andrew
Steviec
Post Thu Oct 13, 2005 8:16 pm
Were there certain models these came on, or was it just an option across the range?
Demlotcrew
Post Thu Oct 13, 2005 8:25 pm
All M3s had them as standard.
Andrew
A1BMW325iSport
Post Thu Oct 13, 2005 11:00 pm
i have them on mine,
gary as i said when i spoke to you earlier i thought they worked with heated mirrors/screen
gazza
Post Thu Oct 13, 2005 11:41 pm
cheers lads the reason for this post is i thought they would be a usefull option wth winter on its way but i have a cab and it does not have heated rear screen or heated mirrors so i wondered how they switch on. the etk shows the loom connects or runs close to the reservoir and it looked like when you use the washers it feeds power to the jets to heat them. i have the jets, and the loom is still available at bmw for about 17 quid.
A1BMW325iSport
Post Thu Oct 13, 2005 11:51 pm
i can trace the loom on mine for you mate, but it will be weekend as i`m out all day 2moro
johnna
E30Zone Irregular
Post Fri Oct 14, 2005 12:04 am
Hmmmm retro fit..... Ԛ£17 Loom from the dealer?
Bargain! Are they tough to retro fit?
Dan318-is
Post Fri Oct 14, 2005 12:10 am
i was also wondering how hard to fit?
A1BMW325iSport
Post Fri Oct 14, 2005 12:36 am
jet parts just clip in, mine were factory fitted.
i`ll have a look at the loom i`m pretty sure there is not much to it
Dan318-is
Post Fri Oct 14, 2005 12:38 am
cheers mate
n e indication as to were it goes would be grand
A1BMW325iSport
Post Fri Oct 14, 2005 12:40 am
2 pin plug goes to each washer jet, then the loom goes down bonnet to hinge area on drivers side, and connects down there i`ll have a look 2moro and tell you more
Dan318-is
Post Fri Oct 14, 2005 12:55 am
a true hero matt
sabrje
Post Fri Oct 14, 2005 2:07 pm
Any idea of the part number for the loom - sounds like a good upgrade....
e30bemer
Nutters
Nutters
Post Fri Oct 14, 2005 2:53 pm
Part no:
61.12.1.380.673
Ԛ£17.96+vat
Gotta be ordered from Germany!!!
Hope that helps
Adam
sabrje
Post Fri Oct 14, 2005 3:49 pm
Spot on - cheers. Time to give the stealers a call..... :cool:
e30bemer
Nutters
Nutters
Post Fri Oct 14, 2005 3:51 pm
no probs mate!!
:cool: :cool:
Demlotcrew
Post Sat Oct 15, 2005 10:00 am
They dont work very well at all!
You need to mod them for full effect.
Andrew
NigelA
Post Sat Nov 26, 2005 9:08 am
Demlotcrew wrote:They dont work very well at all!
Andrew
What does one need to do?
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
Demlotcrew
Post Sat Nov 26, 2005 11:53 am
Well i connected mines to a acc live and put a Thermo switch in the circuit from a E36, what this means is that when the temp gets bellow a certain level the jets will heat up, this is good as wind chill freezes them also.
Andrew
oze30
Post Fri Nov 03, 2006 11:20 am
Demlotcrew wrote:Well i connected mines to a acc live and put a Thermo switch in the circuit from a E36, what this means is that when the temp gets bellow a certain level the jets will heat up, this is good as wind chill freezes them also.
Andrew
Now for thjose that don't speak "demlotcrew"
GDBN
Post Fri Nov 03, 2006 12:02 pm
Gaz ... why does your cab not have a heated rear screen? I thought the warm air blower was standard on cabs.
Heated mirrors were an option ... but it's useful to have.
G
nickso
Post Fri Nov 03, 2006 7:52 pm
the ones i swiped off a well specced 325 were just linked into the live for the washer motor.
should work well enough in my car cos the washer bottle get heated by my top hose :D
'88 e30 328i M52 track bint.
Project_E30
Post Fri Nov 03, 2006 7:57 pm
oze30 Do you want a set as I have a pair for sale.
You will :cry: at the price the dealers charge for the actual washer jets
gazza
Post Fri Nov 03, 2006 8:59 pm
gdbn said ...Gaz ... why does your cab not have a heated rear screen? I thought the warm air blower was standard on cabs.Heated mirrors were an option ... but it's useful to have.
it does have the rear blower this is a very old post if you look at the date ....i wanted to know if mine were working ....they are
Image design cab and now 325 touring
oze30
Post Sun Nov 05, 2006 9:49 pm
I have already. just wanted to know how he wired it up
jmc330i
Post Sun Nov 05, 2006 10:48 pm
Project_E30 wrote:You will :cry: at the price the dealers charge for the actual washer jets
You will :cry: at the price of the non-heated washer jets 8O
James
'91 325i Sport
'93 318i touring 16v
gazza
Post Sun Nov 05, 2006 10:49 pm
i bought a new loom to make them work cost Ԛ£17 but i think the jets were about Ԛ£17 each
