what exhaust clearanceturk wrote:id love to see some pix of exhaust clearance too... pix pix pix
My E30 M3 S85 V10 Swap
glenn
- Engine Transplant Services
Dezzy
- CR24v it's a lifestyle
Trans tunnel mods required?
turk
Inner Wheel arch exhausts
for the deaf neighbours
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
Sump Baffles
TrackDays
UweM3
And I thought fitting a B32 dual sump is a lot of work
FormerMember
Damn that looks good in there.
Seems there's also nicely space for radiator at stock location?
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Dave_M3
Its still tight enough though considering its a cylinder shorter than what you normally have problems with!Jonsku wrote:Damn that looks good in there.
glenn
almost finished the new crossmember, here's a couple of pics......
Dezzy
That looks like some top end fab work right there mate.
MarkT
That looks very robust
E30 340i project in progress now 328 turbo
Breaking '97 728i Auto box, tubular manifolds and other morsels.
For sale E34 M50 sump, pick up and dip stick. PM for de
glenn
made up the engine mounts today, i made them out of some 10mm plate i had left, with some 5mm gusset bracing...they're very strong !
GermanGorilla
Hi,
Glenn- I see you have some E36 M3 Parts.
Do you have by chance a E36 M3 3.0 LTR Crank
in good condition please ?
I really wanted to borrow one to check something.
Seems I am going to have to buy one to find out.
Please let me know if you have one or know of
one.
Regards,
The Gorilla.
one.
Regards,
The Gorilla.
UweM3
I guess with 500+ bhp excess weight is not your concern, lool!glenn wrote:made up the engine mounts today, i made them out of some 10mm plate i had left, with some 5mm gusset bracing...they're very strong !
glenn
hello danny,GermanGorilla wrote:Hi,
i dont sorry, i only break evo's
if i had one you would be welcome to borrow it.
i do have a complete evo engine and 6speed box here though.
hello uwe,UweM3 wrote:I guess with 500+ bhp excess weight is not your concern, lool!
yes, a few kilo's arn't going to be an issue for me, lol
the ecu is in germany, he said he'll be waving his magic wand on it over christmas
GermanGorilla
HI,
Glenn- many thanks, but I need a 3.0ltr E36 M3 one.
Your project is coming on well, are you going
to set the ECU in 'Sport Mode' or retain the
'Push here for 100 BHP Top Up'' Button ?
Regards,
The Gorilla.
Regards,
The Gorilla.
suchy
- True Zone Relic
You could hold the Severn Bridge up with those engine mounts!!
glenn
it will be in P500 mode all the time
it will also come back with a lead/connector, so i can read the ecu on my laptop
lol !! chrissuchy wrote:You could hold the Severn Bridge up with those engine mounts!!
S38B38
Really impressive
Sveinbjörn Hrafnsson
E30 CABRIO M70B50 V12 5lug
ALPINA B10 BITURBO 346@507
550 V12 JML Motorsport
watching with great interest, epic.
Frenchguy
The steering rack location appears to have been moved forward quite a bit. How do you plan to make up for that?
Best of luck to you!
glenn
it's around 100 mm.
i'll get a new column to rack coupler made up
baptie0
what about the steering angle? will moving the rack forward effect it? nice work btw.
glenn
i dont think so, maybe at full or almost full lock, but for normal everyday usebaptie0 wrote:what about the steering angle? will moving the rack forward effect it? nice work btw.
i dont think there'll be any issues. if i find any problems i'll take another look at it.
i thought for a few days, i'd better bolt it all together to check for clearances etc. so, bolted the gearbox up to the engine, so that the engine could sit at its 'finished' angle, and then checked i could shut the bonnet, and check ground clearance.
recognize these ?........
i went down to cornwall last week to pick up some stuff of the old car.
i bought back the interior, the gp-n shocks and springs, my nardi blackline wheel, and these rear quater panels. i thought i'd grab the panels to repair some rust under the back bumper
Dezzy
So is the old car getting put back on the road then?
Looks tight in there.
that looks a tight fit Glenn,
epic thread btw,
epic thread btw,
glenn
he's re-shelling the car.Dezzy wrote:So is the old car getting put back on the road then?
he told me he's bought a dtm new ex-stock shell from germany, and is picking it up this month.
you're telling me steve !!e30topless wrote:that looks a tight fit Glenn
i knew it was going to be tight, thats why i felt the need to bolt it all together and back in the car to check.
i bought back the gp-n shocks and springs, but after bolting it back together, i'm not sure if i could afford to go much lower than it is now, so i may have to re-sell the shocks and springs.
i'm going to remove the engine and gearbox again, so i can properly sort the clutch release bearing, bolt it all back in, then change the shocks and springs and then have a look what clearance i've got under the car.
blitz877
- AKA ajm-e30
how much room is there for a rad in front of the engine then? doesnt look like theres that much room
suchy
- True Zone Relic
Phew, glad you managed to grab the bits back you wanted! Had visions of toasted interior and suspension!! Rear quarters were a bonus!!
As Blitz mentioned also, rad anywhere??
Kos
that spec shell will be about 10k if not moreglenn wrote:he's re-shelling the car.Dezzy wrote:So is the old car getting put back on the road then?
glenn
yes kos, i think it was about £8.5k, without doors, wings, bumpers, glass etcKos wrote:
yes chris, i left enough room for a rad in there when i made the engine mountssuchy wrote:As Blitz mentioned also, rad anywhere??
foz01
Intriguing thread, first post as well, i was lookign to put in aV10 into an E36, E30 M3 was just too expensive as a base car for me, plus almost a shame being a classic ;)
Re the management, i was previously put off but the only proven engine management solution being the pectel/cosworth solution, and its £10k +VAT price tag, i see you are planning on keeping the std management, who has got that working if you wouldnt mind me asking.
thanks
Lowell
thanks
Lowell
glenn
hello and welcome to the 'zone.foz01 wrote:, i see you are planning on keeping the std management, who has got that working if you wouldnt mind me asking
pm sent
Eddy
Phenomenal thread! Keep it up Glenn!
Building my ultimate drift E30....
bmw-mad
Any updates on this Glen?
glenn
well.......bmw-mad wrote:Any updates on this Glen?
my welder packed up, and while that was being repaired, 'er indoors has had
me doing a few jobs around the house.
i've also been doing a s50b32 swap for someone, which i've pretty much finished and so i'll be delivering it back to him this weekend.
also, we're being made to do longer hours at work at the moment, so,
with doing more hours at work,
doing an s50 swap for someone,
and doing some diy,
i'm struggling to get some time on it at the moment.
what i am doing though at the moment is,
preparing the car to go for painting, while its at the bodyshop i'll be able to get the other things finished
andriushka_2000
Hi,
Epic thread!!!
Something that should be done long time ago - and done it the right way! Do you mind me asking the same question as the previous opponent,
any contacts on that, email? phone? also did you ever thought about the new x5m x6m v8 bi-turbo swap??? I believe with your extraordinary abilities it could be done in future?! That`s what I`m looking to do and so - collecting the info on that! I see only one major problem - ems!!! That`s what worries me most. Looking forward that this thing will hit the road asap, interested what`s going to feel while driving this beast! Looking forward that you`ll be able to share your wizard info with me. Thanks for doing this and bringing the positive atmosphere to our minds!
Epic thread!!!
