S14 into 325i..
Mikey_Boy
Post Sun Jan 23, 2011 9:31 pm
Hi all,
Quick one to get the thread started. Outside of the gearbox, prop and diff, a tweek to the exhaust manifold, a different throttle cable, radiator and header tank.....
Would an S14 with engine loom, ECU and airbox be plug and play into a RHD 325i sport?
Many thanks!
Mike
e21Jason
Post Sun Jan 23, 2011 9:35 pm
Pretty much yes, there is a bracket on the passenger wing to take the air box/map sensor but that about it
Jason
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Mikey_Boy
Post Mon Jan 24, 2011 12:15 pm
Thanks... :thumb:
Now all I have to do is find an engine... winkeye
Cheers,
Mike
e21Jason
Post Mon Jan 24, 2011 12:29 pm
Funny you should say that
Thinking putting my supercharged s14 in the car and selling the complete s14 engine box loom ecu rad etc etc Inc Rhd manifold and exhaust
Jason
Z3M Coupe for sale
69 Alfa spyder
Mikey_Boy
Post Mon Jan 24, 2011 12:55 pm
Go on then - I am sitting down... winkeye
PM me a price??
I do have a box installed already however so not sure if you'd be willing to split?
Cheers,
Mike
Mikey_Boy
Post Sun Feb 06, 2011 4:52 pm
Another question related to the transplant if I may:
- Is the fuel pump different on an M3? Does it run 3 bar like the M20 does?
The more I look into this, the more tempting it becomes - I am worried! Seem some really super 2002s with S14s transplanted into them.. winkeye
Cheers,
Mike
bullwinkle
Post Wed Feb 09, 2011 1:09 pm
GO ON, DO IT! I'm looking to do the same conversion into my IS.
I have the engine but am still in the process of getting it all rebuilt (they told me it would be expensive!!), lightened and balanced before tackling the installation. I have a few bits still to source like ECU and airbox but I'm assuming that they are pretty easy to pick up secondhand?
One thing I dont know - will the S14 bolt to my IS 'box? I know the dogleg is preferable but that can come later.
Hope it all works out MikeyBoy!
e21Jason
Post Wed Feb 09, 2011 1:24 pm
No
The s14/m3/m10/s38 all share the same gear box bell housing pattern
Stock air box tends to be around s/h but ECU are not as common
Jason
Z3M Coupe for sale
69 Alfa spyder
Mikey_Boy
Post Wed Feb 09, 2011 2:49 pm
I am still engine hunting!! :thumb:
Worryingly, the conversion is making more and more sense.. winkeye
Jason is spot on - ideally you do need the dogleg box for this conversion primarily because of the bellhousing and also because the gear ratios are so well suited to that engine...
Watch this space!
Cheers,
Mike
bullwinkle
Post Wed Feb 09, 2011 2:51 pm
Thanks Jason.
OK, so would it be feasable to machine an adapter plate to marry up engine and 'box (think I know the answer to this!) if not it looks like I'm gonna need a box.
Regarding ECU, if it's a pain to get hold of, will an MBE (or similar) do the job?
Ta
(Didn't mean to hijack the original thread -sorry!)
Mikey_Boy
Post Wed Feb 09, 2011 3:00 pm
No worries - I think you will definitely need a box...
As an alternative to Motronic, VAC motorsports do an alternative ECU (which is quite pricey - welcome to the expensive world of S14s!!) and Emerald also comes well recommended - put in Emerald 3d into Google :thumb:
Hope this helps!
Cheers,
Mike
MrBenn
Post Wed Feb 09, 2011 3:52 pm
I'm sure somewhere like moselymotorsport would be able to sort you an airbox and ecu.
Doesn't the S14 have a few sensors on the side of the bell housing that would be required if you were going to try and use a different box or adaptor?
Mikey_Boy
Post Tue Mar 22, 2011 9:38 pm
Right - a quick update... I have an S14 engine! winkeye
Thanks to Theo for the engine and associated parts, bascially, everything to carry out the installation apart from the exhaust.
To answer MrBenn's question - the S14 does indeed have sensors on the bellhousing for engine speed and rev counter feed (I think..) so these would be needed...
Watch this space... :thumb:
DawieM3
Post Sun May 15, 2011 9:33 pm
As an S14 powered 2002 owner, just wondered how you are getting on with your conversion.
Regarding ECU`s, Emerald or MBE will be fine. If going to use a std ECU for ignition then look to maxx alpha N setup for fuel, but cost wise , I would go straight for an after market ECU, for ignition and fuel, and then no need for the gearbox sensors.
Cheers,
Dave
E30 M3 Track car S14, 2.5l
2002, 2.0l fuel injected
E30 C2 2.7 Alpina
E36 M3 Evo
1602, - 2.5 S14
2002 E10 -M57 on e46 floorpan
335d - e92
320d -e92
Jag xj8 4.0l
Mitsu L200 animal
Mikey_Boy
Post Fri Jul 01, 2011 6:18 pm
Hi Dave,
Thanks for the advice - the conversion is coming along slowly! I have an Emerald ECU now and the engine is being refreshed with new crank seals, clean up, clean injectors etc etc.
I have a carbon airbox on order and various other goodies coming so watch this space!
Full build report will be posted as it happens!
Cheers,
Mike
p.s. S14 in 2002 - VERY tasty!! :thumb:
Hoobs
Post Sat Jul 02, 2011 7:18 am
Mikey_Boy wrote: p.s. S14 in 2002 - VERY tasty!! :thumb:
You should see it Mike. It's quite some car.
http://www.02forum.co.uk/viewtopic.php?f=16&t=56
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
magicmat
Post Mon Jul 11, 2011 1:44 pm
This should be an interesting build, I know SlideMotorsport did one recenlty and it came out really well :)
not sure if the guy is on there that owns it.
Mikey_Boy
Post Tue Jul 12, 2011 10:49 pm
Ahhhh - just had a look on Slide Motorsport's web page - the car you are referring to has an SR20DET dropped in it - an S14 of sorts (S14 is also a designation for the Nissan 200SX right??)
Just to be clear - I am dropping in a PROPER S14 into my 325 from an E30 M3...
:thumb:
Cheers,
Mike
Latest update - some parts on their way from the USA, most dealer parts bought..
e21Jason
Post Tue Jul 12, 2011 11:17 pm
I have a spare crank trigger set up if you need one.
jason
Z3M Coupe for sale
69 Alfa spyder
Hoobs
Post Thu Jul 21, 2011 11:13 pm
Anyone got an early ECU spare?
2002
Mikey_Boy
Post Wed Jul 27, 2011 8:07 pm
Yep - I have - 87 model year any good to you?
Hoobs
Post Thu Jul 28, 2011 9:04 am
Hi Mikey,
Yes, it would be. I actually managed to get one from Bexley but I guess it wouldn't hurt to have a spare tucked away. How much are you looking for? Prices for ECU seem to vary a huge amount.
2002
Mikey_Boy
Post Sat Jul 30, 2011 9:20 pm
You have PM!
:thumb:
Mike
