what fan's are you lot using for 24v conversions.
Post Tue Jan 18, 2011 2:54 pm
i know i need a front mounted pusher fan.
will a 13" be too small?
what cars are your fans from?
cheers all...
**BANNED**
Post Tue Jan 18, 2011 3:36 pm
E32 air-con fan....
Danthe can supply a suitable loom if you ask him properly,you will need either a radiator with a boss for the temp probe or do what I did and make up something like this;
Should be as close as possible to the radiator.
Youth is wasted on the young.
e30-EVN
Post Tue Jan 18, 2011 4:49 pm
E34 aircon fan here to mate, fits perfectly in the space available :D
Post Tue Jan 18, 2011 4:58 pm
i have a danthe fan loom on the way and my rad has a 3 pin temp switch.
just got a resistor for twin speed :D ,just need to locate a fan hmm.
Post Tue Jan 18, 2011 5:01 pm
not any on ebay and none with a/c in my breakers :(
something else from a more easily sourced turd must be out there...???
hongkongfuey
Mad-tango-geezer
Post Tue Jan 18, 2011 5:12 pm
there is a e34 on in my scrappy if you want it give me a shout
with cars like mine,
Post Tue Jan 18, 2011 5:17 pm
SHOUT!!! ^^ :D
e30-EVN
Post Tue Jan 18, 2011 5:24 pm
LOL :D
Cook318IS
Post Tue Jan 18, 2011 5:27 pm
E36 16" twin speed electric fan,
Post Tue Jan 18, 2011 5:30 pm
do you have to remove the black plastic shroud for the e34 unit?
Paul that fan is bloody Huge 8)
was it hard to mount?
Cook318IS
Post Tue Jan 18, 2011 5:32 pm
The middle part of the fan where the motor is, is about a fag papers thickness from the front valance! It is awesome though. IIRC, one side was ok but the other side needed a small bracket to attach it.
Post Tue Jan 18, 2011 5:36 pm
was it a front mounted a/c fan from a 36 ?
Cook318IS
Post Tue Jan 18, 2011 5:37 pm
I think it was yeah.
Post Tue Jan 18, 2011 5:49 pm
might be getting an e34 one and run it twin speed :)
been in touch with HKF about the one he knows of 8)
Duke137
Post Tue Jan 18, 2011 6:26 pm
The front mounted aircon fans were only on later E36's i think? Might be wrong though
Post Tue Jan 18, 2011 6:29 pm
6 pot E36's to be precise, most 4 pots tend to have a pull fan in the engine bay
Duke137
Post Tue Jan 18, 2011 6:30 pm
DanThe wrote:6 pot E36's to be precise, most 4 pots tend to have a pull fan in the engine bay
That might be what I'm thinking of actually
Post Tue Jan 18, 2011 6:33 pm
just got this from Danthe.
a 13" pusher fan core mounted ,
i found a 13" fan i can do this with and it will only cost me a tenna.
update tomorrow when i get it,hopefully it will mount ok and nothing will be proud of the blades when i remove it :D
Post Tue Jan 18, 2011 8:03 pm
magpie wrote:just got this from Danthe.
That's the one I was on about on the phone earlier Mick 8)
Post Tue Jan 18, 2011 8:21 pm
looks a tidy job,that's monted with 10 mm bolts nylocks and rubber washers 8)
i hope the one i've found is a goer . :)
Post Wed Jan 19, 2011 12:56 pm
paid a tenna total for both these parts :D
one flush fitting 13" pusher a/c fan and a large resistor for twin speed set up.
acquired fan from a hyundai people carrier and the hedgehog from a galant.
flush fit 8)
hedghog has x2 wires to go to the fan and x3 wires at the other end to connect to a Danthe fan loom.
nice little mount bracket :)
