Jesus325iTouring
- Frog freak !
Just ignore them Si and rest upon the fact you're not a complete oem homo
You put the wrong amp fuses in there si
Mate of mine has a td crank but like yours it has some pitting, just get it reground and measured up properly, then plastigauge it when fitting just to be sure
have i? for the A/C i've gone through them to make sure i have the correct ones for the spec. Same with the relays as i need them all now
15 amp for low speed and 30 amp for high speed
many thanks, which goes where?
15 amp fuse 3 = low speed
30 amp fuse 18 = high speed
Better people?
I've whipped off a pina big brake and caliper for Keri WHSmith to have a play and see if a cheaper disc can be done. Just need to drop them off soon at his gaff.
Spent about 2 hours playing with all this, i can't believe it all clipped up nicely. the passenger side is chokka blok. Like a modern car with all the extra loom its sporting, compared to when it left the factory, with keep fit windows. Quick hoover out and its just the sound deadening now for the floor pan. I've also removed all the top and plug in looms to make life a bit easier fitting the carpet and not have looms dropping down in the way all the time! Hopefully its all there as i wouldn't want to add anything i've forgotton which i've checked and checked to be doublely sure.
Powelly carpet miester came round earlier to give the carpet a good scub, hoover first then out with the carpet cleaner stuff liberally squirted on
Then some wet vac action. It was actually really really clean. Must of had mats from new as it wasn't soiled or stained badly so really didn't need all this. Would be rude not to and it will smell nice!
In the lounge to dry, where else would it go for a few days?! Ready for the big day! Can't wait to get this fitted, sad but true
This pest is my main problem now as hes tried to sleep on it about 10 times all ready with that bloody white fur! Spent ages hoovering cat hair off it after i discovered he liked it when i first picked it up. As you can see Dave likes stupid places to get some kip
Carpet has come up nice Si, it did have Mats from new they went into the H27,
that wiring looks fun !
something i need to get my head around is retro fitting elecy windows,
I was only joking.....................Simon13 wrote:
Better people?
Oh and nice pants Steve!
Normally those carpets harbour no end of crap. They will look the shizzle.
gareth
I must admit, my car is not exactly OEM in a lot of ways, but it HAS to have BMW fuses
let me know when you're popping down to see Keri, I might swing by and say hi
i can come down today, rained off work! i wonder if the carpet is dry yet!
powelly
Thanks Trev, Marks and Spencers finest. That carpet was clean as a whistle, barley a spot of dirt came out of it, I guessed it had probably had mats on it since new.
Le Mans Classic 2006-
It rained today so i got another bite at the cherry!
Out with the real tools! well just making a start on the sound deadening for the rear footwells
My closest match for the curve on the corners! old 2.5 piston
Marked up
Cut, not a bad fit. I made them 300x490mm. Truth be told i could of gone 5-10 smaller for a really horny fit, but its under the carpet!
Heat gun it to shape
This new stuff from BMW doesn't come with glue on the back anymore to i sprayed some adhesive down for good measure
Repeat for other side
voila we are in business and ready for the carpet. I've got over half of this stuff left. I noticed M3s seem to have some on the rear shelf? I've thought this stuff is like dynamat and can help in this department later on, so i shall keep it
Twas pretty dry when i got in this morning, but this helped dry it a bit quicker!
Whilst i was waiting and checking that light drying the carpet every 10 mins. I p!ssed about with other bits. In a sad way last week i hunted down in the bentley manual all the torque settings for the running gear. Just to be a bit geeky really but my main reason was to double check that nothing was loose or forgotton etc. So now hopefully nothing will fall off when its driven for the first time! I did the rear last week, really quite boring micking about with torque wrenches. Always pays sometimes to double check
Trevor has kindly been plating again and heres some bits. Thanks. Agreed some of it should be silver but our brothers in South Africa had other ideas when they built their E30's! Alot more of the bits on SA cars are finished like these bits. Even the servo which i think looks pretty cool, i nearly kept one for this car!
I'm feeling it, either looks good. Top is OE european built. Bottom SA. Before people say the bonnet runners are silver, when do you see that and the catch together? You don't! cos the bonnet it up innit
Anyone remember or look at their car and see if i've got this on the rightway round please?!
Ta Da!!! i've taken 1 pic
What a f**king horrid job. I hate fitting carpets, this was no exception. The end result it nice but........those bloody 3 rubber tube/grommets for A/C box i posted the other day. Well the rubber just grips the foam on the carpet! Made it even worse sliding up the tunnel. Then i pulled one off, i won't comment any more. I didn't want to lube the tunnel like some people do, but that must help massively
I wanted to fit the plastic weather strips, which i can't because i need to buy new door weather/rubber strip thing. They really do shrink! This one is nice condition but its gone too small. They're £84 EACH from the dealer. So it can wait.
Being on a roll i've given this some action tonight also. Its minging and not fit for this wagon as is. So lets fettle the A/C, climate box! The ultimate factory option in E30 heating, also the heaviest
All in bits and leaves and bits of sh!t everywhere!
I tried to remove the loom but couldn't work it out, so left it like this and stripped the horrid old tape off.
Gave these bits a hoover, then the plastic bits a good wash and dry off. Also the main unit as best you can
Re taped up and now i have no more. 1 role has been enough to do most of the car really
Blower cleaned up, it span freely but i've given it a tickle with the spray grease and the resistor was good
fitting it all back together, if i didn't do it today i could see me forgetting how it all went. Its easy enough though. I've never stripped an e30 heater box down of any type till today funnily enough
All up together awaiting the finishing touches
New gaskets for the cream pie! A mucky old job to start but well worth it. I'll strip the box down a bit more as it won't fit as is becasue the A/C boxes are too big with the heater valve on!
Marked up
If you want to lube anything like those rubber A/C drains Si use waxoil, it wont rust anything and repels water, dont get better than that!
Another tip, before that heater goes in get the matrix in the sink and wash all the crud out, I used kettle de-scaler in mine and couldnt believe the amount of shite that was stuck in it
tonybtonyb
Great job mate keep up the good work
gareth
Top work Si, that's some serious homo shizzle right there
Another brilliant use for kettle descaler is to remove that beige ceramic looking deposit from exhaust valves. pop them in an old pan and simmer for a while and it just softens and wipes offDanThe wrote:Another tip, before that heater goes in get the matrix in the sink and wash all the crud out, I used kettle de-scaler in mine and couldnt believe the amount of shite that was stuck in it
beardymat
- Location: sheffield, city of steel, and rust apparently
Dont they look a lot closer to being finished when the carpets go back in?
I started to clean my climate box up like that but it decided to jump on the floor lemming style whilst my back was turned, Broke a couple of small but very important parts of the box which are unrepairable so now i need a spare box but it seems like a regular aircon box can be converted to climate with the right parts. Was in a right huff on the way home that night.
oguz327
- Captain Armco
Awesome Simon, progressing nicely now fella!
Theo
Great update! It's ust dawned on my that this is actually going to be finished soon, how long since you bought the car?
Matt, what parts did you break on your climate box?
beardymat
It broke the heater box casing in two places both of which are flap pivots so they broke through the hole, i had the pieces but i came to the conclusion that even if could glue them chances are it would soon break off again meaning the dash would have to come back out. I may have one sorted from billgates but am still keeping my ear to the ground for one particularly if someone has just the casing spare.Theo wrote: Matt, what parts did you break on your climate box?
Dezzy
- CR24v it's a lifestyle
Every days a school day for me reading this thread. Great work Si, and thanks for the detailed write ups.
glenn
- Engine Transplant Services
i can see the finish line in sight.
without reading back through 70 pages!, is that black carpet the one that came out si?
Theo
Let me know if Chris can't help, I do have a spare climate heater box.beardymat wrote:It broke the heater box casing in two places both of which are flap pivots so they broke through the hole, i had the pieces but i came to the conclusion that even if could glue them chances are it would soon break off again meaning the dash would have to come back out. I may have one sorted from billgates but am still keeping my ear to the ground for one particularly if someone has just the casing spare.Theo wrote: Matt, what parts did you break on your climate box?
No i bought it off e30topless in about April last year i think Glenn. I'd given up all hope of ever finding a factory black carpet. I've still got the grey one i was going to use instead but patience paid off in the end!
So the whole interior will be black. Is that too much? nah I'm going to dye the rear parcel shelf. I did it on my old sport and it came out well.
http://www.e30zone.net/modules.php?name ... sc&start=0
Heres the original thread March 2006. But i bought it in, Feb 2006 in think*
Matt i have about 4 heater boxes here in a all guises. stock, climate, A/C so if the others can't help i should be able to
I'm glad to see others faith is returning about seeing a new tax disc in the window! 2011 it happens
Dan i thought earlier about some flushing action would be a good idea for the matrix, yours is one step better
glenn
i think the black carpet looks fantastic. i'd love one, butSimon13 wrote:No i bought it off e30topless in about April last year i think Glenn. I'd given up all hope of ever finding a factory black carpet. I've still got the grey one i was going to use instead but patience paid off in the end!
if you struggled for so long to find one, there's no chance of me finding a lhd black one....is there?
I think LHD black carpets are still available ?
Simon13 wrote:......after it has been sprayed when i find £1500 to do it
try £1500 in panels! i didnt know then what i do now.
I always thought LHD carpets can be had still, they were £300 but since E30's went mobile tradition the prices for evertyhing have gone spastic from BMW but worth a check.
BMW are c*nts and I hate them for what theyve done to prices
Who the hell fitted a DTM dross pipe to your pina!
not me, was there when i bought it. It was a nearly new system, the centre box has baffles still and didn't howl
CHR1S1990
are these hard to come by then? were they an optional extra? trying to figure out why my scrapper has one - a really low spec 325i auto. and no, its not just dirty lolSimon13 wrote:I'd given up all hope of ever finding a factory black carpet.
very in my experienceCHR1S1990 wrote:are these hard to come by then? were they an optional extra? trying to figure out why my scrapper has one - a really low spec 325i auto. and no, its not just dirty lolSimon13 wrote:I'd given up all hope of ever finding a factory black carpet.
CHR1S1990
thanks. ill have to hold on to it then and put it in my daily. loving the work btw, alpina FTW
pegase747
A/C retrofit looks to be a pig of a job, I guess I should be happy mine is there already....
I was thinking of removing it because didn't bother much about retrofitting it to r134, but I may as well keep it and convert it !
Keep up the good job Simon, nearly there !
Pierre
Pierre
Sh!t.
