B7's Next Installment. Rear End Action! SHE'S HOME!!!!
Post Sat Nov 20, 2010 7:37 pm
a fair days work today. Not as far as I would have liked but the fuel tanks in, plumbed up, heats sheilds re fiited, beams in and diffs in.
But started with the snapped stud which the rear spire nut secures the exhaust backbox heat sheild in place. Riv nut to the rescue again with photos this time :D
Heres the tool in place
Heres the fixing secured into the pre drillled hole
and the heat shield ain't going no where!
Fuel tanks in and time to plumb the fuel filter and join up with the new pipes.
'friad it's a bit OEM Homo again!!! The fuel filter backet is one of a few I plated up earlier this year.
and with filter in and plumbed up
Then came something I was in two minds whether to do. I went for it in the end and got the waxoil kit out and protected the edge of the fuel tank. We all know these rot so best try to keep it at bay. I did the top befor it went in along with the box areas to the sides around the beam mounts.
Next came the heat shields with my newly plated brackets
The beam went in a treat and I reckon looks okay.
Followed by a refurbed 3:64 LSD with M3 mount. The casing has already started rusting but where do you draw the line!!!!!!
and the prop rebolted up with newly plated nuts.
And thats where I left her today. Wanted to get the arms in but I've lost the bloody rubber link pipe from the filler neck to the tank!!!! :x As it is I'kll have to work around the beam! Before that though a light dusting of waxoil over the boot floor will protect the old thing for a bit longer.
Dezzy
CR24v it's a lifestyle
Post Sat Nov 20, 2010 7:44 pm
Terv i have looking forward to these pics all day :o:
I knew they would be epic. You havent let me down. great work mate. :cool:
Post Sat Nov 20, 2010 7:45 pm
Nice work Trev 8)
glenn
Engine Transplant Services
Post Sat Nov 20, 2010 8:07 pm
just had my first read of this thread trev...brilliant! 8)
that plating looks ace
winx
Post Sat Nov 20, 2010 11:41 pm
good work sir, looking lurvely.
Post Sat Nov 20, 2010 11:49 pm
really nice 8)
jonb
Post Sun Nov 21, 2010 12:05 am
Love the silver spray paint on diff plate. And whats with the "s" ontop of the rust?
Post Sun Nov 21, 2010 12:19 am
So clean underneath.
Post Sun Nov 21, 2010 7:30 am
jonb wrote:Love the silver spray paint on diff plate. And whats with the "s" ontop of the rust?
How you doing? :D
goosiegander
Zonegoose
Post Fri Dec 10, 2010 4:27 pm
B7 wrote:I'm tempted si but I'm sitting with a brand new BMW battery worth the best part of £80 quid and common sense tells me I should be happy at that and just use it.
However, the little voice on my right shoulder says "It has to be white and you know the big mans gonna rip it out of you every time you open the bonnet" :o:
Just sent you a pm :D
Post Fri Dec 17, 2010 11:16 pm
B7 wrote:Spent most of the day with the plating kit fired up. All a bit boring really but I thought it best to get it out of the way.
All the bolts for the rear end are now ready for the reassembly.
Heres what annoys me the most about BMW new parts. Just raw mild steel!! Thats just going to look REEEALY nice afer just a few weeks!!!!
So I plated those as well.
Trev , sorry to be a pain but what kit did you buy to reproduce these? any tips on doing the plating ? :)
Post Sat Dec 18, 2010 8:07 am
e30topless wrote:[Trev , sorry to be a pain but what kit did you buy to reproduce these? any tips on doing the plating ? :)
You sir are never a pain, it's always a pleasure.
Bought one of these:
http://cgi.ebay.co.uk/Zinc-Electroplati ... 3cb364152c
It's a bit Chad Valley and a bit hit and miss but if you take yiour time and do exactly as the instructions state, the above is achievable.
Hope that helps mate.
Post Sat Dec 18, 2010 8:15 pm
Awesome ! thanks Trev,
there's shed loads of bits I want to plate, I'm going to need a big bucket ! :D
scott180gtb
Post Sat Jan 01, 2011 4:08 pm
I'm going to be trying this kit as well. The results look well worth £55.
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone :(
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
Post Sat Jan 01, 2011 7:13 pm
The kit will be set up tomorrow to replate and passivate the bracket for the cruise as well as a few bits for Si's c2.7 resto.
The car WILL be back on 4 wheels by this time next week. :D I have 2 days set aside to complete the rear end overhaul. Roll on spring for the MOT.
Also bought the following for it to detail it a bit more.
New throttle pedal
All new screws and clips for the inner arch protectors on the front
New white knurled nut for the throttle cable (need to order another for the cruise when it's fitted)
New TRANSISTORIZED sticker for the coil
New Alpinwiess 2 sticker for the NS front turret
New Running In label for the windscreen
New clips for the top of the grilles
More very soon..................
Post Sat Jan 01, 2011 8:24 pm
whats the stricker for the coil?!
scott180gtb
Post Sat Jan 01, 2011 9:12 pm
Hello Trev
Did you use any of the acid pickle baths from ebay to clean up the old bolts first or just bought new bolts and plated them? The Zinc plated stuff you are producing looks like the quality that BMW should be supplying now not the hit and miss I have found when ordering new shiny bolts.
Scott
Cars
Post Sat Jan 01, 2011 9:44 pm
Simon13 wrote:whats the stricker for the coil?!
No3 on here Si. Although it's been superceeded by a new design. However, it'll look better than a tatty one
http://www.realoem.com/bmw/showparts.do ... g=71&fg=03
Post Sat Jan 01, 2011 9:45 pm
scott180gtb wrote:Hello Trev
Scott
No. Go to Tescos and buy two 2.5 litre plastic cotainers of Sarsons Vinegar. Soak parts until clean. Some rusty parts will leave some pitting but so will an acid bath.
Post Sun Jan 02, 2011 10:24 am
noice cheers, i haven't got that one! i cleaned the old label off the my coil as it was skanky
Post Sun Jan 02, 2011 11:14 am
managed to get some plating done last night so here, as a preview for when I hand them to Si tomorrow night
The following for the infamous c2.7 rebuild
1 x coil bracket
2 x bonnet location plates (only 1 shown the other was drying)
Alternator bolt with cog and nut
1 x brake pipe bracket
1 x wiring bracket for side of battery tray.
and
My cruise activator bracket.
And heres the parts I just bought inc that coil sticker Si.
I've also just started work on a genuine excellent alternator I have here. I've stripped the pulley off it and replated the nut and washers / spacers in yellow passivated finish and the main fan blade I've tried the blue passivated finish whick gives a cross between a galvanised colour and zinc plate. Quite pleased. Once the unit is cleaned and reasembled I'll post up the completed photos. My alternator in the car has a slightly noisy bearing so this will do the trick.
Dezzy
Post Sun Jan 02, 2011 2:43 pm
They do look niiiice.
I think i will invest in one of them next time thechromie gets a strip down
Post Wed Jan 05, 2011 8:28 pm
A few shots for todays action. Got the arms back on and I have the f*cking scars to prove it :x
Had the offside on a jack manouvoring into position, laying under it and the cow fell off the jack and cut my head and ear open!!!!! What a c*nt!!
Still, the arms are on, Handbrake adjusted, looms clipped up, fuel filler plumbed in and the driveshafts semi in before I collapsed into a heap and came home. Too many late nights on the p1ss over xmas I reckon.
Apologies for the photos, camera has a fault it appears and didn't realise until I got home. It seems the camera and the car fought me today. Back over there on Friday to get it on all fours, fit the exhaust, Sort the brakepipe at the front end and breed the brakes.
Dezzy
Post Wed Jan 05, 2011 8:36 pm
Looks really nice Trev.
It's nice knowing you have a clean ar5e isn't it. winkeye
telski789
Post Wed Jan 05, 2011 8:38 pm
looking good matey!!
Post Wed Jan 05, 2011 10:27 pm
Loverly trev! 8)
scott180gtb
Post Thu Jan 06, 2011 1:51 pm
I like this thread a lot!
Trev are they new drive shafts? Were they expensive?
Cars
Post Thu Jan 06, 2011 2:00 pm
New driveshafts are over £300 a piece! 8O
Royalratch
Post Thu Jan 06, 2011 2:04 pm
Details details details.
scott180gtb
Post Thu Jan 06, 2011 3:01 pm
That hurts! :eek: Is that from the stealers? Can they be re-furbed?
Cars
Post Thu Jan 06, 2011 4:10 pm
They are just the originals refurbed. I didn't even think about buying new when theres nowt wrong with the ones I have. The only thing that is not original are that the boot clips would be silver.
Royalratch
Post Thu Jan 06, 2011 4:55 pm
B7 wrote:The only thing that is not original are that the boot clips would be silver.
Tut tut. Shoulda paid the extra.
gareth
Post Thu Jan 06, 2011 11:55 pm
Can i see rust on your diff? 8O
Looks spot on Trev :thumb:
Post Fri Jan 07, 2011 12:14 am
Sorry to be a pedantic mo fo Trev but the bonnet guide roller bracket things are not meant to be plated.
Unless thats an OEM homo award winning mod? :wink:
gareth
Post Fri Jan 07, 2011 12:49 am
While we're being pedantic (i didn't start it! :) ) it looks like that plating is on those rollers is: Zinc plate with a colour passivate. Most of the 'silver' BMW parts are a zinc plate with a clear passivate.
Is there an alternative passivate that can be used with that kit?
