e34 sump
garymillscab
anyone know what other sumps i can use for my m52 swap as 525 ones seen abit hard to come by. would a 520 sump be ok or is it 12v? also would i use the oil pickup ad dipftick from the same car
wanted- all parts for m52 conversion
e30-EVN
as long as it comes from an m50 varient it will be fine afaik mate
m50b20
m50b25
m52b28 ect
m50b20
m50b25
m52b28 ect
e30-EVN
by the way..... not from an e36!!!!
so an e34 with an m50 engine as above mate
E34 or E38, its in the parts list sticky at the top of the section
rob0r
A stupid question, and I guess there's a good reason why not as everyone would be using them... Do M20 sumps have the same sump bolt pattern? M20 and M50 blocks are very similar but I've never had the M20 sump up close near an M50 engine.
If they did, we'd all be using them
garymillscab
It's not far out tbh but not close enough
mattmk1
Iv not had a look at my sumps either, so this may be an horrendously stupid question, but...
Can you not have the M20 bolt holes re drilled to match m52 block?
And as it also looks like i need to source an E34 sump, why wont the E36 one fit? Is it massively different? Can you not have the E36 sump cut and welded to fit?
Or are these sumps cast or alloy etc??
If so, is there not enough room to run a sump spacer plate to take up the offset on the bolt holes? Using a longer oil pickup??
garymillscab
would a sump from a e39 528 fit? im realy struggling to get hold of one grr
Cook318IS
vvvvgarymillscab wrote:would a sump from a e39 528 fit? im realy struggling to get hold of one grr
there are about 7 24v e34's being broken on ebay, have you asked any of them about a sump?DanThe wrote:E34 or E38, its in the parts list sticky at the top of the section
garymillscab
yup messaged them all most are saying there selling the engine complete if not they arent open or there already gone
e30-EVN
@mattmk1- E36 m50 sump won't fit because the pan is on the back as a pose to the pan on the e34 sump siting infront of the e30 steering rack.
Also they are alloy mate
GemE30
Andy325i is selling an e34 sump. He offered it to me a couple of days ago but I sourced one from ebay.
garymillscab
Thanks for your help guys got one sorted picking it up Tuesday
