Ant MAF Magic
petrol_1
Post Sat Nov 27, 2010 10:02 pm
Just been down to A TECH and had His MAF conversion on my 2.7.
Wow impressive!
The difference is big , compared to before !
(Even my wife noticed the extra Torque,) it will pull top gear from approx 1000/ 1200rpm ( on a 3.6 diff) and drives like its got lot more cc under the bonnet.
The spread of torque is really impressive and its a lot more responsive all round too )
No problems or down side only +++
All Ants R&D Time REALLY shows ( he's a true perfectionist ) and wont give up till its Right
Cold start is perfect (even today frozen icy one !) , pulls harder than before with instant throttle response ( not like the normal elastic std e30 one )
At motor way speed the MPG meter showing 40 / 50 at light throttle 70/80 So MPG will be better too
Also hes done me LPG specific chip too , Best of both worlds
A great job ,
Many thanks Dude [/b]
m_jermyn
Post Sat Nov 27, 2010 10:10 pm
Does this need to be done on a dyno or is it plug and play?
This is the next thing I do on my car
petrol_1
Post Sat Nov 27, 2010 10:41 pm
LIVE MAPPED , on mine ( but its on LPG and i had specific goals , which he achieved too )
but i beleive if you gave him the full spec whether std or tuned , i m sure he could sort you out , even in Sydney
My sequencial lpg ECU is now running more advance than std and afr of 17 / 18 :1 at idle so this is going to be so much better on fuel economy too , and we ve found that from a matched petrol to LPG fuel map this conversion is now needing approx 20 % less fuel at WOT when on LPG ,
BUT IS THE DRIVIBILTY THATS MOST IMPRESSED ME ,
Put this on your xmas list your E30 NEEDS THIS MOD
Speak to Ant a @ A TECH
Post Sat Nov 27, 2010 10:45 pm
Sounds great dude. Which engine is it?
petrol_1
Post Sat Nov 27, 2010 11:05 pm
Its a M20 ETA bottom end with 731 head
I ve got a std ETA ENGINE in an e30 too & this conversion is far more torquey than a std ETA and there built for T ,
Ajsingh
Post Mon Nov 29, 2010 8:00 pm
The standard eta bottom end... Did you change the big end bearings to stronger ones ie 325i ones or did you just keep the standard eta ones?
E30 Crazy!
petrol_1
Post Mon Nov 29, 2010 10:09 pm
Std ETA shells / bottom end
Just for remembed
I lighten the flywheel on this one , so the drivibilty is even more impressive than i first thought as it pulls so well
e301988325i
Post Sun Dec 05, 2010 4:14 pm
Bookmarked, Ant what MAF are you using for the conversion? A siemens E36 one?
I said:
e30topless said:
lock the wife in there
DmcL
Post Sun Dec 05, 2010 4:47 pm
most likely.. that or a volvo one, think both are very similar, both are 4 pin anyway. actually been thinking of grabbing a 328i or M3 MAF just to see how similar and to try/compare both side by side as wel las swapping sensors/housings as i think the E36 housing is a little bigger than the volvo one. volvo one is perfectly sized to fit the standard TB elbow but its a little small for my liking, especially since i got that 64mm TB installed winkeye
WMMotorsports
chu346
Post Mon Dec 06, 2010 7:46 pm
So if this is a non standard engine type with an off the shelf chip, then after a live mapping session the car will be much nicer to drive.
I'm not too convinced on the maf conversion on a standard engine, but in this case where you needed a live remap anyway I'm sure it's worth it.
toby
Post Sat Dec 11, 2010 9:32 pm
I've driven one of Ant's MAF converted cars and the top end was particularly impressive.
scott180gtb
Post Tue Feb 01, 2011 2:23 am
How much does the MAF conversion cost. I will need this for my 2.8 donk.
JazzMan
Post Thu Feb 03, 2011 6:35 pm
scott180gtb wrote:How much does the MAF conversion cost. I will need this for my 2.8 donk.
I'd be interest too for my 28 :)
TouringTash
Post Thu Feb 03, 2011 6:44 pm
Why not get in touch with the man fellas?
www.fastbimmer.co.uk has all the info you need. Email and phone number. :thumb:
318i Touring
petrol_1
Post Fri Feb 04, 2011 4:09 pm
Give ANT a ring
Tel: 01959 534718 -
Email: ant.woodjetts@googlemail.com
hes alway busy so keep trying it will be worth it
AFM are RESTRICTING your motors Potential
TouringTash
Post Fri Feb 04, 2011 7:08 pm
just email him as most of the time he's making far too much noise to hear a phone.
Or is that just when I'm there?
318i Touring
fowler
Boost Junkie
Post Sat Feb 05, 2011 8:48 pm
jay its usually me making all the noise lol but yes chaps give him a call or alternatively drop him an email with all the car details and it will get responed too on mon or tues when i am down there. :D
EX A-Tech Workshop bitch !!!
gone but not forgotten
petrol_1
Post Mon Feb 07, 2011 10:57 pm
Ben
Is /when is atec moving ?
nearer to me last time i spoke winkeye as i want to book the caddy in
fowler
Boost Junkie
Post Fri Feb 11, 2011 5:51 pm
not sure yet mate best to give ant a bell or drop him a mail matey
cheers
Ben
