Rear arch/tyre clearance
Post Sun Oct 31, 2010 8:25 pm
I cant be arsed to mod the arches yet, will trim them and roll the lip properly another time, but for now, is this likely to catch on hard corners?
This is with the spring removed and the wheel lifted, in reality the wheel isnt going to lift that high, the gap is just over 10mm
Post Sun Oct 31, 2010 8:30 pm
Erm yes by the looks of the pics, if you "Bottom" out anywhere, you fook up the tyre.
martinpallot
Post Sun Oct 31, 2010 8:31 pm
Should be safe. Although under hard use there is enough give in the rear beam and rubber bushes to cause 10mm of movement, its unlikely that the inside wheel would be loaded enough to push the wheel that high in the arch unless the car is run very low.
Post Sun Oct 31, 2010 9:06 pm
Its not low at all, that was with the arm lifted right up to the adjustable spring seat, with the spring in it wouldnt go that high.
Under cornering, would the gap get bigger or smaller?
si-
Post Sun Oct 31, 2010 9:42 pm
modding the arches is easy, heat gun the paint not to hot but not to cool you need the paint to be plyable, rubber mallet and gently bend the lip up, easy peasy and not difficult at all
i waxoyled the crap out of mine before i did this though
tbh the best way to find out if they are going to rub, is go and try it
Cook318IS
Post Sun Oct 31, 2010 9:49 pm
Get a larger man to jump on the back and see how much effort it takes to get the back as low down as possible. If the arches do catch, its a track car - get ghetto!
[youtube][/youtube]
Driftben
Post Sat Nov 06, 2010 10:05 am
Cook318IS wrote:Get a larger man to jump on the back and see how much effort it takes to get the back as low down as possible. If the arches do catch, its a track car - get ghetto!
[youtube][/youtube]
haha that vid is wicked but why isnt he using his seat to roll his arches? that is a cool seat.
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
Post Sat Nov 06, 2010 9:00 pm
Didnt catch, for the record
