Zoners track day cars
e21Jason
Wed Mar 25, 2009 7:00 pm
looks nice jason, a lot different than last time i saw it.
Yeah I think I have past the point of no return, it's snowballed into a full spec track car.
The quality is spot on and Kyle is a busy man so you need to book it in about 1/2 months in advance.
Jason
nickso
Wed Mar 25, 2009 7:24 pm
Jason
handy to know. mind telling me how much you were for that setup? mine probably wont be quite so high a spec.
'88 e30 328i M52 track bint.
SteMarsden
Fri Mar 27, 2009 10:20 pm
My PBMW build..... car #40
BMW E30 318i ex PBMWC track car
2011 VW Passat Est
mccarthy
Sat Mar 28, 2009 7:53 am
just wondering what peeps use to take the tar/gllue type stuff off that remains when scraping off the sound deadening?
lm11
Sat Mar 28, 2009 8:53 pm
Mine so far...
These so-called speed bumps are a joke. If anything, they slow you down! :-x
SteMarsden
Mon Mar 30, 2009 11:32 am
Mccarthy,
I used a scraper and then paint thinners to get the sound deadening off (but it leaves your brain and paintwork a lit bit dull!)
8O
The paintwork may improve with a polish, but at the end of the day its a track car so Im not that bothered tbh.
The brain may take a little longer to return to full strength!
I did try petral which isnt that good, but make sure you use in a well ventilated area blah blah blah.
Ste.
2011 VW Passat Est
mccarthy
Mon Mar 30, 2009 11:42 am
nice, thanks mate. dreading doing it!
flyingfarrier
Mon Mar 30, 2009 8:16 pm
engine degreaser works well and without to many fumes,
Lloydie38
Wed Apr 22, 2009 10:10 pm
I did mine with a wide chissel and a heat gun - easy as, one hour later, all gone ( weight gone 21lbs) don't forget behind the rear side panels / wheel arches... Cleaned it up with thinners, got a rattle can of hammerite in white - bish bosh done. 8)
M3BOB
Tue Apr 28, 2009 12:24 am
whats the matter with having a track car on polished splitties ? :mad: how do i put a pic up
Jim78
Tue Apr 28, 2009 8:01 pm
Lloydie38 wrote:I did mine with a wide chissel and a heat gun - easy as, one hour later, all gone ( weight gone 21lbs) don't forget behind the rear side panels / wheel arches... Cleaned it up with thinners, got a rattle can of hammerite in white - bish bosh done. 8)
Hey Lloydie. Been wanting to ask about what you have done with the car where the brake ducts and fog lights usually reside. I have bought some mesh for my E30 with the intention of placing this in the hole that is left when ducts and lamps are removed and then doing away with the ducting and plastic shields in front of the wheels altogether. Is this what you have done. If so, should I do the same or keep the ducting set up and just place the mesh where the foggies were?
Any thoughts appreciated..... :)
Lloydie38
Thu Apr 30, 2009 12:20 am
I've got the wife banging on the bedroom floor and shouting come to bed.....I'll post an answer to brake ducts and fog lights tomorrow when....ahh bollox I'm off for a sh
Jim78
Thu Apr 30, 2009 6:53 pm
Cool - don't want to cause a domestic! :cursin:
Lloydie38
Thu Apr 30, 2009 9:08 pm
God I was good winkeye
Anyway, I've removed the fog lights and ducts and replaced with mesh. I'm not sure that the brakes get the air as efficiently as if the ducts were there... I've bought another set of ducts and I'm going to fit them. On Track I use yellow stuff, braded hoses and 5:1 fluid and it takes a real hammering but not had any brake fade...yet. For a cheap brake solution it's kept fairly well ventilated by the B&Q mesh :D
scaraveos
Sun May 03, 2009 3:58 pm
Some pictures of my track day car:
The specs can bee viewed here:
http://p-bmw-e30.net/mye30specs.php
rix313
Tue May 05, 2009 4:27 pm
Here's mine so far:
Whats going in it:
Charger:
Lightend fly wheel and new clutch:
Yet another M42:
The finished spec will be:
Super charged M42
FMIC (fitted)
4pot 280mm brake upgrade
Braided clutch hose
Braided bracke hoses
4.1 LSD
15inch wheels with the humble R888
Electric fan (fitted)
Remote oil filter (fitted)
Single head light conversion (fitted)
Poly bushed front and rear (rears fitted)
SPAX PSX stiffness adjustable suspension (fitted)
Megasquirt or similar ECU system
Uprated injectors and FPR
COP conversion
What I want to do after:
Gaz coil overs
Eibach adjustable ARB's
M3BOB
Tue May 05, 2009 4:36 pm
pic at http://i43.photobucket.com/albums/e385/ ... 085601.jpg
1990 m3
welded in cage
glassfibre front wings,bonnet,bumper
glassfibre rear bumper, bootlid, roof replaced with single skin, sunroof gone
leda coilovers,braided lines, part polybushed, airbox and alpha, cams, flocked dash, seats harnesses and fire system
Jim78
Tue May 05, 2009 5:46 pm
M3BOB wrote:pic at http://i43.photobucket.com/albums/e385/ ... 085601.jpg
1990 m3
welded in cage
Looks fantastic Bob. Where abouts in Kent are you? I used to live round the corner from Bexley Motor Works in Bexleyheath.
M3BOB
Tue May 05, 2009 7:59 pm
Looks fantastic Bob. Where abouts in Kent are you? I used to live round the corner from Bexley Motor Works in Bexleyheath.[/quote]
Im near Rochester
MrBenn
Wed May 06, 2009 4:20 pm
rix313 wrote:Here's mine so far:
Super charged M42
FMIC (fitted)
Braided clutch hose
4.1 LSD
Gaz coil overs
Looking good Rix, do pop over if your free on Satuday, Alex
MrBenn
Wed May 06, 2009 4:22 pm
1990 m3
welded in cage
Mmmmmmm very nice indeed.....won't be long now : )
M3BOB
Wed May 13, 2009 7:01 pm
found some other pics and one of my road car
http://i43.photobucket.com/albums/e385/ ... ackCar.jpg
http://i43.photobucket.com/albums/e385/ ... oadCar.jpg
enjoy
they dont seem to come up but you can look at my albums i think
http:// i43.photobucket.com/albums/e385/m3bob
Lloydie38
Fri May 15, 2009 12:55 pm
1990 m3
welded in cage
Car Porn - Fantastic :cool:
juniorGT
Fri May 15, 2009 3:43 pm
bob seen yours at the prept brands hatch meets a few times.. truly is a work of art in the flesh !
shall pop over for a chat next time
Josh
318is.
M3BOB
Tue May 26, 2009 11:53 pm
pics working now
LondonTom
Wed Oct 27, 2010 11:14 pm
Here's mine, still very much work in progress:
Spec as follows:
Non Vanos M50b25
328i 'box
3.64 LSD ( I need a lower ration one!)
Gaz gold coilovers
Polybushed
Wilwood 4 pots front
Standard 325 brakes rear
15"BBS with toyo's for track
Stripped interior
Cobra buckets
To do list:
Change the diff to a lower ratio
Fit my recaro srd's
Buy and fit a cage
Fit some form of heat sheild between the exhaust and the floor - gets far too hot!
Long term is to build a decent m52.
Suede momo wheel
MillRat
Thu Oct 28, 2010 1:10 am
Mine;
And, latest look;
Specs are;
Series 1 E30
M20B29 (IE stroker kit),
272 IE cam,
BBTB and Hottuning headers,
Miller 3" MAF with WAR chip,
KW V2 with Eibach adjustable F & R sway bars and Noltec adjustable camber/caster plates,
Alpina 296mm front rotors with E36 328i calipers,
Performance Friction PC06 pads all round,
Powerflex subframe and diff bushes,
AKG poly engine and gearbox mounts,
AKG sports shifter,
3.73 and 4.10 LSD differentials,
Walker Chassis cage,
Sparco GP seats,
TRS 3" 6 point harnesses,
Sparco 383 steering wheel (not pictured) with Sparco quick release,
BBS RS 16x7 rims with Bridgestone RE01-R semi's,
Alpina front bar.
Who would have thought that so much fun could be had, in a car shaped like three Lego blocks?
Cheers,
Michael.
Driftben
Sat Oct 30, 2010 6:44 pm
Heres my old drift slag
D2 coilovers
RB25DET
Huge front cooler
S14 front brakes
and lots more iv forgotten about
and this is my current one
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
MarkT
Sat Oct 30, 2010 7:04 pm
Here's how mine (axel) stands... Sorry!
Finished spec will be.
M52B28 which will be low pressure turbocharged.
Fully adjustable suspension geometry, based on the DTM car set-up.
Front and rear coilovers, turreted rear
Blade adjustable front ARB (hopefully in car adjustable one day)
Mazda 4 pots and 280mm disks, 325 rear set-up
Welded in cage
So far, fabricated the coilovers and the adjustable geometry stuff. Slow build to start with but now picking up a lot of pace :D
E30 340i project in progress now 328 turbo
Breaking '97 728i Auto box, tubular manifolds and other morsels.
For sale E34 M50 sump, pick up and dip stick. PM for de
Duke137
Sat Oct 30, 2010 7:19 pm
This thread is just porn.
chips
Was Pzero
Was Pzero
Sat Oct 30, 2010 7:27 pm
Here's mine. Not much left to do. Hoping to go to a track day in November but that might just be wishful thinking...
Lloydie38
Sat Oct 30, 2010 8:18 pm
Agree 100%.. :-)
Motorhole
Sat Oct 30, 2010 11:55 pm
Here's mine in its current state, still a long-term work in progress unfortunately! But this year so far it has gone from this:
To this:
Bristol_Jer
Sun Oct 31, 2010 10:21 am
This is mine:
So far it has:
Speedtouch wild chip
Yellowstuff front pads + new discs
KW 60/40 springs
Bilstein B4's (going to swap for some GAZ shocks when funds allow)
4.27 diff
15" BBS wheels
Boot trim and back seats removed
IS front seats
Electric fan conversion
I've done 2 track days in it so far, obviously its not too quick on the straights as it is only a 320 but is great round the bends and can usually make up for the lack of outright pace on the bends :)
Plans for it now are to strip down the rear end and rebuild with new bushes, fit new brake hoses and pipes, and get the few welding patches sorted, then engine conversion sometime next year. So far its cost me less than a grand including buying the car so it's a bit of a budget build really.
Theo
Sun Oct 31, 2010 10:54 am
Spec:
SR20DET engine running approx 280bhp & 280ft/lbs
GReddy baffled sump
13 row oil cooler with remote filter housing
Large alloy radiator
Front mounted intercooler
Alloy flywheel and heavy duty RPS clutch
Custom 2.5" stainless exhaust system (single box)
Blitz adjustable dual solenoid boost controller
Gaz 'Gold' coilovers
Spherical bearing top mounts (fronts adjustable for camber/castor)
H&R anti roll bars and spherical bearing drop links
Alloy wishbones with Treehouse Racing bushes
Poly-bushed rear beam adjustable for toe and camber
Strut braces
3.91 LSD with 40% lock
Fuel swirl pot and walbro 255 fuel pump
Wilwood pedal box with remote bias adjuster
280mm front and rear brakes with braided hoses
E46 M3 steering rack
GRP bonnet
Hartge bootspoiler
BMW 'aerodynamics' front spoiler
15" BBS with Toyo r888 tyres
Motordrive composite seats, Sabelt 3" harnesses
Fusebox relocated into cabin
Lightweight battery behind passenger seat
Safety Devices 6 point rollcage
Approximately 1050kgs
