Foot panels...
spic
Post Sat Oct 09, 2010 9:09 pm
Hi Guys and girls ... with the carpet out What are you useing on the floors of you track and race cars ?
Any pics would be good... Thanks
Steve.
UweM3
Post Sat Oct 09, 2010 9:49 pm
skateboard grip tape
furbster
Post Sat Oct 09, 2010 10:40 pm
I'm using skateboard grip tape at the moment too but have been toying with the idea of getting these....
http://www.bmtown.com/imagedata/all/alu ... oors2L.gif
spic
Post Sat Oct 09, 2010 10:59 pm
UweM3 wrote:skateboard grip tape
Have you got this directly on the floor ?
UweM3
Post Sat Oct 09, 2010 11:02 pm
yes.
and on the pedals as well (rubber removed)
I am not a fan of checker board. Climb in with wet feet..... winkeye
furbster
Yep, just heated with a hair dryer to make it more plyable and stuck it directly to the floor. It has torn in a couple of places now though but easily repaired.
Cheapest way to stop you whacking your knackers on the roll cage when the floor is wet! :mad:
Kos
Post Sat Oct 09, 2010 11:53 pm
exaxtly what i've just got ! :D
spic
Post Sun Oct 10, 2010 12:33 am
I have a half a meter of this as i just applied it to my pedals, its got to be a lot cheaper than an alloy floor thats for sure !
ross_jsy
Post Sun Oct 10, 2010 3:13 pm
+ 1 on the grip tape. Those aluminium boards are lethal in the wet.
GeoffBob
Forced Induction Specialist
Post Sun Oct 10, 2010 4:03 pm
Aluminium tread plate (checker board) coated with UBS-100 (a part sticky rubber, part gritty sand type coating) is an excellent non-slip surface for both wet and dry. Any untreated or uncovered surface (aluminium, mild-steel or otherwise) is ill-advised in the wet.
Rallyprep_UK
formerly Driftnething
Post Mon Oct 18, 2010 11:24 pm
Im using skateboard grip tape also :)
Racing is living, everything else is just waiting...
http://www.rallyprep.co.uk
si-
Post Mon Oct 18, 2010 11:39 pm
haha ive just had the exact same tape turn up, good choice :cool:
Rallyprep_UK
Post Mon Oct 18, 2010 11:40 pm
haha ebay is the best winkeye
si-
Post Mon Oct 18, 2010 11:42 pm
sure is!!
how much did you use i havent fitted mine in yet i bought 2 rolls
Rallyprep_UK
Post Mon Oct 18, 2010 11:43 pm
I bought 2 rolls also and I think I only used one...
but im sure it will need re-doing at some point :)
si-
Post Mon Oct 18, 2010 11:44 pm
that'll do me enough for the passenger side aswell then 8)
