Foot panels...
spic
Hi Guys and girls ... with the carpet out What are you useing on the floors of you track and race cars ?
Any pics would be good... Thanks
Steve.
Steve.
furbster
I'm using skateboard grip tape at the moment too but have been toying with the idea of getting these....
http://www.bmtown.com/imagedata/all/alu ... oors2L.gif
spic
Have you got this directly on the floor ?UweM3 wrote:skateboard grip tape
UweM3
yes.spic wrote:Have you got this directly on the floor ?UweM3 wrote:skateboard grip tape
and on the pedals as well (rubber removed)
I am not a fan of checker board. Climb in with wet feet.....
furbster
Yep, just heated with a hair dryer to make it more plyable and stuck it directly to the floor. It has torn in a couple of places now though but easily repaired.
Cheapest way to stop you whacking your knackers on the roll cage when the floor is wet!
Kos
exaxtly what i've just got !UweM3 wrote:skateboard grip tape
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
spic
I have a half a meter of this as i just applied it to my pedals, its got to be a lot cheaper than an alloy floor thats for sure !
ross_jsy
+ 1 on the grip tape. Those aluminium boards are lethal in the wet.
GeoffBob
- Forced Induction Specialist
Aluminium tread plate (checker board) coated with UBS-100 (a part sticky rubber, part gritty sand type coating) is an excellent non-slip surface for both wet and dry. Any untreated or uncovered surface (aluminium, mild-steel or otherwise) is ill-advised in the wet.
Rallyprep_UK
- formerly Driftnething
Im using skateboard grip tape also
si-
haha ive just had the exact same tape turn up, good choice
Rallyprep_UK
haha ebay is the best
si-
sure is!!
how much did you use i havent fitted mine in yet i bought 2 rolls
Rallyprep_UK
I bought 2 rolls also and I think I only used one...
but im sure it will need re-doing at some point
si-
that'll do me enough for the passenger side aswell then
