225/45/16 - will I get away with it?
To small
Throws the speedo out, gives a firmer ride, more chance of buckling a rim and looks to small in the arch.
I am stuck in the 80's though!
- Kos
- Contact:
stick with your fords
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
I havent owned a ford for 3 years!
I'm firmly with the old school for this one...
Was running 215/40/16 for a while and found them far too hard. Strangely the back end was also quite slippery and the whole lot felt crashy but without any discernable benefit in grip.
Switched to 205/50/16 and it feels loads better - almost like BMW intended, but with 16s!
I was planning to try to fit 225/45/16 on the rear, and many people say you can get away with it with the right spacer setup (I run 20mm spacers all around) but in the end cost killed that idea! 225/45s are SO expensive!
- Kos
- Contact:
bss325i wrote:I havent owned a ford for 3 years!
IG Pukar.Designs
IG Pukar.Designs
StuBeeDoo
OK, here's the pic, and I took some measurements as well to back it up.
The absolute outer edge of the tyre is 8mm beyond the extremity of the rim. The outer edge of the tread is 14mm in from the outer edge of the tread. .... And the tread is bang on 205mm wide.
I wouldn't call it stretched, it seems spot-on to me.
Cost isn't really an issue as I wont be replacing them often as the car is just a summer cruising wagon.Ilkorin wrote:I'm firmly with the old school for this one...
Wow, this may have convinced me - does look spot on.StuBeeDoo wrote:OK, here's the pic, and I took some measurements as well to back it up.
Thanks for the pic.
Im leaning this way - though not if im going to have them machined when I can fit 205/50s and them look like Stu's.Blitz wrote:205/50 front and 225/45 rear. Job done.
Hmmm.
So Bob, now that you have finished with E30 scrap, when are you going to sell me "the wheels"?
Bob_S
Not *quite* finished yet.. I still have a little bit of unfinished business. My S50 is still here all BTB'd up sat next to a mountain of parts.. All my scrap has gone all the shit cleared out just left with some choice parts I've even sold my alpina's!bss325i wrote:So Bob, now that you have finished with E30 scrap, when are you going to sell me "the wheels"?
Bollocks to this 24v scrap!
MadE30mike
Ziggy
Mine are 205/50, also 7.5j ET20 & on a convertible... struggling to find pics that show the tyres particularly well though!
http://www.e30zone.net/modules.php?name ... c&t=162523
