Pointless post maybe
Intake manifold off
William
- Location: Home:Suffolk, Uni: Cirencester, Gloucestershire
dazleeds
- old skool raver
def get gaskets and do it while off
but i would not take the manifold off noo way just the tb trust me will take ages if you take full inlet off hth
www.oldskoolfantasy.co.uk
Simon
As Daz said, taking the inlet manifold off and replacing it in 20 mins is a no!! To replace the TPS, just unbolt the TB, easy peasy 5 mins at the most, you can usually re-use the TB to inlet gasket, as it doesn't usually fall to pieces, but have another ready just in case!
William
Adammcf
Not sure what engine you have but on the 325 its litterally a two minute job to take off the throttle body. The inlet manifold is a pain in the ass to take off.
dazleeds
- old skool raver
just make sure you have a mini socket set with pencil thin extension bar and its easy
