can anyone tell me where i can buy new ni-cad batteries for my service
indicator lights the one`s you have to solder in
its for 1987 E30
logga
service lights
Ziggy
Sorry, I don't know the answer but it is relevant-ish... Do they really use ni-cads, & how does the charging cycle work if they do? Just thinking that nimhs might be a worthwhile upgrade either way??
A1BMW325iSport
Hi guys, yes the are rechargables Radioshack i think do them maybe maplins as well? what board you got Jon as i got one here with good batteries you could have.
Matt
Matt
Ziggy
Cheers mate, but mine doesn't actually need doing! Just wondering about the use of ni-cad cells & memory effects etc & thinking that nimhs would potentially be a better choice...A1BMW325iSport wrote:Hi guys, yes the are rechargables Radioshack i think do them maybe maplins as well? what board you got Jon as i got one here with good batteries you could have.
Matt
I *do* need a reset tool though!
A1BMW325iSport
soz should have read the post better doh!
anyway logga - i got a board with good batts if you want it dude,
otherwise like i say u can get new batts and solder em in.
Jon, have heard of people using nimh batts and them working fine.
Matt.
Matt.
E30Adam
A good upgrade if you're changing the batteries is to get remove the 2 old batteries and then solder a battery holder to the SI board battery terminals and run the wires through the instrument cluster casing.
Situate the battery holder somewhere concealed under the dash and if they do again, you can just pup out the old batteries and put new ones in, then you won't have to remove all the instrument cluster and start soldering batteries.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
ed325i
There are two sizes fitted the AA size and there are ones that are half the size I found this out when I went to change mine.
BadDave
You don't really need aretet tool.Ziggy wrote:Cheers mate, but mine doesn't actually need doing! Just wondering about the use of ni-cad cells & memory effects etc & thinking that nimhs would potentially be a better choice...A1BMW325iSport wrote:Hi guys, yes the are rechargables Radioshack i think do them maybe maplins as well? what board you got Jon as i got one here with good batteries you could have.
Matt
Take a look at [url]http://www.bmwe30.net%20%20and%20it%20gives%20details%20on%20how%20to%20do%20it%20there.All%20you%20need%20is%20a%20short%20length%20of%20wire%20(with%20a%20fuse%20in%20the%20middle)[/url]
A1BMW325iSport
pin 7 to pin 1 with a short length of wire iirc
yeah they used diff batts on the later E30`s
Matt
Matt
Ziggy
Ah that did the trick
Guest
AB1BMW325iSPORT
did you say you have a spare board for a 318 E30 what will it cost me dude,
logga
logga
