thanks
Another sticky throttle pedal
William
- Location: Home:Suffolk, Uni: Cirencester, Gloucestershire
fastcarz464
I think u need to replace the throttle cable, its cheap from gsf or euro parts that should get it right.
SCOTT325SE
throttle cable is cheap enuf from stealers too mate. try going for a refurb on the throttle system - probably improve responce a load too
Chaos
try opening the throttle (under the bonnet) by hand, if thats not too stiff etc then the problem is likely the cable
Chaos
causing havoc and mayhem wherever i go
William
