coolant pipe split
m30e30
Sun Sep 19, 2010 5:46 pm
my beloved beast let go today its the pipe that goes from the heater marix to the back of the cylinder head siple enough but i have an m30 lump in mine and im not sure if
a: its an e30 standard pipe
b: its the pipe from an e28
c: doesnt matter there the same
can anybody help
cheers
Sun Sep 19, 2010 6:28 pm
BMW coolant hoses usually have the part number printed on them.
m30e30
Sun Sep 19, 2010 7:04 pm
its a bit old and busted now cant see any numbers on it
Sun Sep 19, 2010 7:42 pm
You might get a better response to this if it's moved to the M30 section in the "engine swaps" forum.
Sun Sep 19, 2010 7:51 pm
A quick look at that forum suggests that you might have an E28 engine, rather than the preferred E34 motor, as it appears that only the E28 head has the outlet elbow on the back of the head that your hose is connected to.
Do you want your post moved?
m30e30
Sun Sep 19, 2010 8:51 pm
yes plz
leeparkes
Tue Sep 21, 2010 7:23 pm
If you havent sorted this yet im guessing an M20 pipe would work.
hongkongfuey
Mad-tango-geezer
Mon Jan 10, 2011 7:49 pm
there is an e24 in my local scrappy untuched are the pipes the same?
with cars like mine,
gareth
Mon Jan 10, 2011 10:05 pm
after a quick search on realoem.com, it looks like they are :) Not that expensive new though...
