Or even the extra weight of a sub box and ampDezzy wrote:Maybe the wrong diff?DanThe wrote:Must be an M30 ECU ehRav335uk wrote: "Computer says No"
CR24v Custom M52B30 FTW. New Exhaust, New gearbox and Fan.
- E30 Zone Meets/Events Team
Nice one, even had a chuckle to myself on that line.DanThe wrote:Must be an M30 ECU ehRav335uk wrote:"Computer says No"Dezzy wrote:Link doesn't work for me.
Dezzy, I have a working car for POD
Cook318IS
Hardly counts if you're not going to run it up the strip imoRav335uk wrote:
Dezzy, I have a working car for POD, do you?
Dez, if you get a move on and get this thing running I can have a word with a mate and see if we can get you squeezed in for mapping next week, its only a case of bedding the rings in and you will be good to go. Would be good to see you going down the strip at full chat
The only "Full Chat" Dezzys doing is the ones saying "My car won't be ready"DanThe wrote:Dez, if you get a move on and get this thing running I can have a word with a mate and see if we can get you squeezed in for mapping next week, its only a case of bedding the rings in and you will be good to go. Would be good to see you going down the strip at full chat
Get your Arse in gear, you've been at this long enough now, fook, even i'll come and help you get the thing running!
M50 is too complicated for you Rav, no coil/dizzy to go wrong you see
Dezzy
- CR24v it's a lifestyle
Dan its not going to be possible mate. I running the place from Tuesday next week. Only time off is Sunday for pod.
The difference is Rav i have done a COMPLETE conversion. Everything has been changed.
I have built a custom engine, changed and uprated everything and all you have to do is fit a 3.64 open diff.
Come on even you can see that a pussy way out.
I meant as in "Get it Going to the Scrapyard" Dan, makes no odds on the thing have coils or dezzys, oh I meant dizzys
You've got more on your plate than me then, ive not booked anything in for next week so I can get my own car ready!Dezzy wrote:Dan its not going to be possible mate. I running the place from Tuesday next week. Only time off is Sunday for pod.
Dezzy's and mine will be there next year
Well you have had open offers of help Dezzy, I have no issues helping out getting the thing going.
All i need is a hammer and blowtorch
Dezzy
Dezzy wrote:The finishing off list is:-
Fit fan, rad and wire the loom. Done
Fit waterpipes Done
Finish the last of the engine loom wiring off Done (need icv)
Fit inlet manifold, throttle body, airbox, maf and throttle cable Done
Swap to 2.8 injectors Done
Wire in the lamda
Finish welding the manifolds (that i will do this week at work) DONE
Finish bolting the prop up Done (finally)
Swap E34 engine mounts for my 635 ones
Check the gear selector is finished Done
Bleed brakes & clutch Done (brakes need doing)
Fill gearbox oil Done (thanks Steve)
Sort a custom powersteering pipe. DONE
Fit 6 pot code pin to clocks Done
Secure ecu & fit pannel under clocks Done
Fit battery tray and batetry into boot Done
Re fit Jimmy hill and undertray and gearbox sheild
Fit M3 battery cover and M40 loom cover Done (thanks for supplying the M40 cover Mick)
Fit rear M3 14.5mm ARB Done
Finish the exhaust system (make it fit downpipes)
Fit my 16" ronals
Fit dogging blind clips Done
Wire in my becker radio Done (Cheers Alex)
Run it in and get it Mapped
Few bits and bobs now. Getting theer
You got a lambda yet Dez?
Dezzy
Rav335uk wrote:Well you have had open offers of help Dezzy, I have no issues helping out getting the thing going.
Having seen what you have done to your car Rav, i thank you for your kind offer......
No fooking way are you going anywhere near my car
Dezzy
I have a 4 wire one bud buts its off some french turd.DanThe wrote:You got a lambda yet Dez?
I have enough length from the loom of yours to just cut and join that though.
I will bell you about that and some other loom issues if that box turns up tomorrow
It should do, sent it recorded delivery
I will have a look at the bone yard tomorrow, might be a 5 showed up since I was last there
Dezzy
Really appricate all the Help mate!
In fact i have said it before but thanks very much for all the zone help i have had
i'm in for sunday DanDanThe wrote:Same here magpie, will you be there?magpie wrote:Progressss! fookin Ace.
[youtube][/youtube]
looking forward to this years pics and vids
Just watched that vid again, doesnt feel like 3 years ago!
if only for inspiration ;0))
not sure why linky aint working.
this might???
stop smelling ya finger Dez you know it stinks after picking yo ass!
+ a yard full of scrap turds
I have an M50 4 wire lambda mate, think the wiring mat have been butchered near the plug & need re-joining. It's yours if you want it?
Dezzy
See what yoda turns up tomorrow mate. If not I will defos have it!
leeparkes
Where did you get that silicone inlet hose from dezzy?
Dezzy
An American website mate. I didn't find it. Pm with details.leeparkes wrote:Where did you get that silicone inlet hose from dezzy?
Kos
this car is coming along very nicely
me like
me like
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
Dezzy
Cheers mate.
Dezzy
Right then. The drive looks a bit strange.
Not under it's own steam but it's defos an improvement.
It's sat on the ramp at work awaiting finishing off.
Fit ivc, TB, inlet boot and airbox
Plug rest of loom in and fan loom to finish.
Bleed brakes and powersteering.
Finish exhaust
Fill coolant
Fit undertray and jimmy hill.
Oh and the clutch is right in the middle of the pedal too!
Getting neverous now.
Finish exhaust
Fill coolant
Wooo
Not long
The_Diddler
- Love it up the more door !
billgatese30
I am expecting to see this at the Pod Dez
Dezzy
Fingers crossed it will be there lads.
Chris did anything come of that lhd turd?
billgatese30
Might be seeing it on the way to the Pod, from the pics it looks like a very nice turd, but its still a secret
Dezzy
Ok mate. I thought it might be. Mums the word.
Pod's calling
Good progress dude
Good progress dude
Fingers crossed for you Slappy
Dezzy
Cheers lads
Dezzy
Just ready for finishing lads
More info on progrees today hopefully
