kat
robbiehartge
Hartge Crew
Tue Sep 27, 2005 7:37 pm
can i get rid of my kat. it a april 92.
Dan318-is
Tue Sep 27, 2005 7:39 pm
luckily yes
it was august 92 the law came in i believe
darren318is
Wed Sep 28, 2005 12:07 am
yes! ive been waiting for this topic never thought to write it.... anyway...... my cars a 91 318is any one know wat law on that is in rep.ireland probly same they wudnt expect you to put one init! what sort of perform. gains expected on a 318is? would emmissions be problems them and is this justb cut it out and weld pipe in job!
Dan318-is
Wed Sep 28, 2005 12:09 am
im not sure about legality in ireland
as for emissions obviosuly it would probably fail an MOT
i imagien a bit of power would be gianed from it tho, as for the job in hand iv no idea
all i can advise is that u dont go 2 quick fit!
HartgeH27
Wed Sep 28, 2005 1:24 am
318-is wrote:luckily yes
Agreed !!!!
Emissions
Vehicles must meet European emissions standards. Please note that petrol-fuelled cars manufactured after August 1992 are required to meet standards that can currently only be achieved by a catalytic converter.
kbis
Wed Sep 28, 2005 9:10 am
anyone know if theres a decent cheap decat pipe available ie from supersprint or any other manufacturer ?
had an alfa 156 before my 91 318is and the cat went on that(honeycomb disintegrated and ended up in the back box) cleared the honeycomb out and drove for a couple of months like that..the only problem was the nasty rasp the exhaust gave off due to gas expansion in the empty cat, eventually had a 'csc dummy cat' made and shipped over from italy, it had a built in silencer. sorted the awful resonance, nicer exhaust note than standard and a bit more response on the throttle. Ԛ£120. and as the car had two pre cats it still passed its mot no probs. but that was then..anyone else decatted their 318is got suggestions? any resonance problems etc..
cheers
kb
E30Mark
Wed Sep 28, 2005 9:21 am
I bet your 318iS doesn't have a CAT, check under the battery tray there is a connector there. If its blanked off then you don't have a cat/lambda sensor fitted. If it does have wiring running down to the lambda sensor then you do have a cat.....
Everyone seems to think they have a CAT on the 318iS, I've said it before, but if you do actually have one then I'll give you a prize! who in there right mind would tick the CAT option box when given the choice???
The front box is just a resonator
PM for details
Danstable
Wed Sep 28, 2005 11:18 am
I'm about to remove the Cat on my 1991 325 Tourer......then it's going in for it's MOT. Is it going to fail on emissions??!
BrAdZ
Wed Sep 28, 2005 11:21 am
nope it will be fine!
Danstable
Wed Sep 28, 2005 11:31 am
Luverly......thanks!
Danstable
Wed Sep 28, 2005 11:33 am
Big_M_
Wed Sep 28, 2005 11:49 am
Lads, just get some stainless/mild steel pipe the same diameter as your exhaust, two flanges to match the ones already on the cat, get the pipe cut to lenght, weld on the flanges remove the cat, bolt in the kat replacement piece, job done. then when your going for an MOT just do the swap. cheap and easy. while we're on the subject, i new a guy driving a FIAT Punto, he failed the MOT on emissions, then he took the cat out went back re-tested and passed the f***ing MOT. :) :D
Big_M_
Wed Sep 28, 2005 11:50 am
Big_M_
Wed Sep 28, 2005 11:53 am
Big_M_
Wed Sep 28, 2005 12:06 pm
sorry about the repeats lads, site was telling me message was not sent oops :cheese:
Dan318-is
Wed Sep 28, 2005 12:31 pm
adam agreed with the cat
mine doesnt have one just got a front resonator
what sort of gains can be expected from this?
darren318is
Wed Sep 28, 2005 3:53 pm
would a front 'resonator " look lik a cat on outside and my car has a piece of wire going to where the end of manifold meets single pipe looks like a spark plug is this lamda sensor and do u tink this a cat
darren318is
darren318is
Wed Sep 28, 2005 3:54 pm
darren318is
Wed Sep 28, 2005 3:55 pm
my car looks like tit has cat cold this be resonator? it has sensor too?
jmc330i
Wed Sep 28, 2005 4:10 pm
I think the iS has an all-in-one Cat and front box, but I could be wrong.
If you have the Lambda sensor (wire going to the exhaust) its likely you have a Cat, but not always.
Normally I would say, get rid of the Cat and leave the Lambda sensor in place, although Ive been told on here you can dump the sensor as well, as the ECU can run both open and closed loop. That was for the M20 engine though, so the M42 might be different, ie if you remove the sensor you need a non-Cat ECU - that will need confirming by the 318iS experts on here.
IMO I would remove the Cat if you car is registered pre August 1992 and leave the sensor in place as its there for a reason.
I did remove the Cat on my Oct 1992 registered Cav SRi and that passed a couple MOTs with no problems before I sold it.
James
'91 325i Sport
'93 318i touring 16v
darren318is
Wed Sep 28, 2005 5:04 pm
so any confirmers on jmc330i's opinion
darren318is
Wed Sep 28, 2005 5:07 pm
E30Mark
Wed Sep 28, 2005 6:12 pm
If you've got a wire going to the exhaust then yes you do have a CAT... like i said never seen one fitted before! the front resonator does look like a 'typical' CAT of sorts, that's why so many people think they have one fitted.
looking at the ETK, it doesn't list a different ECU for CAT equipped cars, disconnect the lambda sensor and see what happens!
PM for details
William
Location: Home:Suffolk, Uni: Cirencester, Gloucestershire
Thu Sep 29, 2005 8:54 pm
Big_M_ wrote:Lads, just get some stainless/mild steel pipe the same diameter as your exhaust, two flanges to match the ones already on the cat, get the pipe cut to lenght, weld on the flanges remove the cat, bolt in the kat replacement piece, job done. then when your going for an MOT just do the swap. cheap and easy. while we're on the subject, i new a guy driving a FIAT Punto, he failed the MOT on emissions, then he took the cat out went back re-tested and passed the f***ing MOT. :) :D
just be careful with this, most people forget that just because your car has passed its MOT, doesn't mean your insurance company will take a liking to you 'modifying' things. The insurance is on the basis of having a valid MOT certificate, if on inspection the MOT does not represent the car's current config. then you'll be in trouble if it came to that after a serious inspection
:thumb:
Big_M_
Thu Sep 29, 2005 11:29 pm
same applies to any mod though even changing wheels, lowering kits, induction etc, etc. its just a risk we take. rules are made to be broken well insurance ones anyway so long as you get away with it, besides if you get the cat back pipe made to look original then the inspector would have to be a zoner to know the differance, lol :)
kbis
Fri Sep 30, 2005 7:06 pm
when i dectat'd my alfa one of the potential issues was the ecu over fueling due to the lambda providing inconsitant emissions info, was advised to have the chip remapped. could removing the cat and or lambda on a 318is cause any specific or similar probs that anyone may be aware of?
kbis
