Which exhaust
booomer
I'm hopefully soon going to be having my m52 manifolds modified but i'm wondering what options i have for the rest of the exhaust? What has everyone else done? i have a complete e34 m50 system but don't know wether any of it can be used on an e30?
E30 325 systems are OK.
If you can get an aftermarket stainless system, they will typically have larger bore pipes. I think on an E36 328i, the bore of the stock system is 48mm.
I have fitted an E30 M3 scorpion system and it has 50mm pipes all the way through and I have 50mm down pipes welded upto the 328 manifolds.
booomer
Am i rite in thinking that there are different types of 325i exhaust system that were fitted to the e30?
Baz666
when i had my m50 done i just used my standard twin 325 sport pipes. and now i have twin stainless it sounds the nuts.
i have a stainless back section for sale from an e36 but dont know if they differ much.
leeparkes
Is it twin pipe in twin pipe out?Baz666 wrote:i have a stainless back section for sale from an e36 but dont know if they differ much.
iirc Toby unna fitted an E36 328i rear box to his E30.
Baz666
yeah Lee scorpion twin all the way through.
booomer
So anyone know if e34 stuff is at all useable?
booomer
Anyone know the outside diameter of e30 325i exhaust front section pipes where they come up to the manifold?
Jozi
How hard are E30 M3 exhausts to get? Is the much involved in mating the M3 exhaust with the m52 manifold?
Would the M3 system be more suited that the 325 one, near enough same power out put from a s14 and a m50/2
blue30
They're 45mm OD give or take a few tenths on an OEM 3 piece part.booomer wrote:Anyone know the outside diameter of e30 325i exhaust front section pipes where they come up to the manifold?
leeparkes
You can either get a flange made up and weld it to your downpipes (im sure Gareth has a Cad of this) or cut the flange off the system and sleeve it onto the downpipes.Jozi wrote:How hard are E30 M3 exhausts to get? Is the much involved in mating the M3 exhaust with the m52 manifold?
iirc E30 325i system is 46mm OD
Doesn't BTB do a full system for the M50/52 conversion ?
has anyone bought one ?
the Exhaust is the only thing I hate about my M50
hongkongfuey
- Mad-tango-geezer
i spoke to fritzbits the other day and they do a complete system
with cars like mine,
