Was pissed off so went and tried to find out in the other car, and blew that one up too!! Talk about not learning from your mistakes. What a numpty!
Man I've been a cock with the glove box light
William
- Location: Home:Suffolk, Uni: Cirencester, Gloucestershire
Was fitting a new one that jon sent me, and like a true cock juggling thunder cunt, I did it with the ignition on. As a result, SOMETHING went crack, and the light went out. The fuse is fine, the bulb is fine and the switch is fine, so can anyone shed some light on what the hell i have blown up??
glenn
- Engine Transplant Services
sorry william but i had a giggle at this.Was pissed off so went and tried to find out in the other car, and blew that one up too!! Talk about not learning from your mistakes. What a numpty!
all i can say is try everything and see what isn't working fella
Fair chance it was the fuse that went crack. 21 on early cars, 4 on later ones.
A1BMW325iSport
when removing or fitting make sure to remove the fuse or disconnect the battery, as its perm live and will short on the glovebox latch on removal unless you are really careful not to let the connector touch the metal latch
tylerma
I am sure he wants to hear this nowA1BMW325iSport wrote:when removing or fitting make sure to remove the fuse or disconnect the battery, as its perm live and will short on the glovebox latch on removal unless you are really careful not to let the connector touch the metal latch
William
yup thats exactly what i have done, twice!! what have i shorted out, because the fuses all looked fine and the interior lights on the same circuit all worked fine. I am perplexed!! Tested the switch and bulb on a seperate circuit and they both work fine!! What have I done!!A1BMW325iSport wrote:when removing or fitting make sure to remove the fuse or disconnect the battery, as its perm live and will short on the glovebox latch on removal unless you are really careful not to let the connector touch the metal latch
johnono
pmsllike a true cock juggling thunder cunt
William
johnono
sorry will
, i couldnt help but put it back up, ive read it like 8 times and it makes me larf out loud i dont know why
im loking on the etk for u right now.. trying to find elec.diags so u can trace a poss. short ;)
THUNDER CUNTS HOOOOOOO!!
Martinaston
You may have melted the spring that holds the bulb in place
There is NO nucleus.
johnono
johnono
nope, cant find any diag. for glove box, cant find light fitting also
sorry fella, but does it work on another car anyway?
William
yeah it does mate that's what is so weird, each individual component is fine, bulb, switch and fuse, and it worked in the other car until I blew that one up aswell, that is why im SOO confused!johnono wrote:nope, cant find any diag. for glove box, cant find light fitting also![]()
johnono
what about one from another car to 100% be sure it isnt the light fitting
Martinaston
If you don't re-assemble the spring and washer's correctly they cause a short.
This problem came up the other week and no one could find a diagram then either
William
johnono
ok, and u have swapped the fuses round in each car?
then what about testing the wires for electical current, if one dont work, then u have burned one up..
then all u have to do (yeah easy
) is trace the wire up to the junction / fuse box and change it
William
There's only one inline fuse on a facelift E30, and it's nothing to do with any lights.
