noisy m52
vokietis
Wed Jul 07, 2010 10:08 pm
finished my m52 conversion,started the car and ooops,it has strange ticking/knocking noise,can't really tell where it's coming from :cry:
engine was 100% good before i took it out from an e39.
Wed Jul 07, 2010 10:12 pm
Could be any number of things, exhaust manifold leaking, flywheel catching on sump, something not done up properly like engine mount, exhaust rubbing on something etc etc etc
lambda sensors done up tight?
Wed Jul 07, 2010 10:15 pm
Did you remove the sump baffles?
Wed Jul 07, 2010 10:26 pm
Ticking and knocking are two very different noises.
How long had it been out of the 5 before you started again in the E30? My guess is a sticky lifter or two, common if the engine has been sat dry for a long time
vokietis
Wed Jul 07, 2010 10:37 pm
Jhonno wrote:Did you remove the sump baffles?
no
vokietis
Wed Jul 07, 2010 10:38 pm
DanThe wrote:Ticking and knocking are two very different noises.
well it's more like knocking,and yes it sat dry for about 12 months
Wed Jul 07, 2010 10:44 pm
This one should be removed
vokietis
Wed Jul 07, 2010 10:45 pm
oh no :mad: are u saying crankshaft is touching it?is it possible to remove the sump without removing engine?
Wed Jul 07, 2010 10:46 pm
I can imagine what is happening... :eek:
Wed Jul 07, 2010 10:48 pm
Not all E34 sumps have them though, only the 2 litres
If you left the pressed steel scraper plate on you wouldnt have been able to fit the sump with that baffle
vokietis
Wed Jul 07, 2010 10:53 pm
DanThe wrote:Not all E34 sumps have them though, only the 2 litres
yes i did leave the plate...
Wed Jul 07, 2010 10:55 pm
You must have used a 525 sump then which doesnt have the baffle
vokietis
Wed Jul 07, 2010 11:02 pm
DanThe wrote:You must have used a 525 sump then which doesnt have the baffle
yes i think so,because sump fitted with no probs at all.
vokietis
Sat Jul 10, 2010 10:58 pm
sorted thanks,crank was touching the plate due to my stupidity :D
Sat Jul 10, 2010 11:09 pm
vokietis wrote:sorted thanks,crank was touching the plate due to my stupidity :D
:thumb:
